Trans lines to RAD or cooler
I have a medium size cooler attached to the front of the radiator on my '72 U code Supreme, and I just have the lines running to the cooler. Even in the brutal SE VA heat, I have no issues.
My car has just the internal radiator cooler, and there haven't been any issues in the past.
If SE VA has brutal heat, I don't even know what to call what we have here in Phoenix. It's gonna cool down to the low 100s next week and that's a relief.
So my car came with some twisted up lines maybe i should buy a new set of replacements i saw inline tube sells them.
Anyone have a diagram where they run ? do they run near the motor mount or around exhaust by the frame?
I forget.
I usually dont have to mess with them.
Thanks!
I forget.
Thanks!
Thanks for the explanation of how the external cooler should be hooked up. I have been wondering the same thing myself.
[QUOTE=69CSHC;1276891]Guys has any performance muscle era Olds come with additional coolers from birth ? I would think a 68/69 Hurst Olds is the most likely candidate, followed by 1967-1972 W30...
I definitely saw a '70 442 loaded with almost every imaginable option that had the factory aux cooler setup and tow package at our Zone Show. Beautiful Twilight Blue with blue interior. It had the original window sticker. It was later for sale on C/L, and then some time later was on EBay out of FL.
I bypassed the radiator and connected the hoses straight to the cooler with no problems. I even raced through the 1/4 mile with no problems.
If adding a cooler wouldn't it be better to route the RPO way, internal radiator cooler first, then the auxiliary cooler and then the transmission?
If it goes to the auxiliary cooler first then the trans it would add heat from the radiator.
It looks like the RPO went to the radiator first.
With a transmission that has a non-lockup converter, it probably doesn’t really matter which order the auxiliary cooler/radiator cooler goes.
Transmissions that have lockup converters have the radiator cooler after the auxiliary cooler. If you look at a hydraulic flow chard, the cooler is bypassed by the TCC valve in the pump. That’s so when your on the highway in -20 degree temps, the transmission doesn’t get too cold. With the converter locked, no converter slip, and no heat. Cold fluid doesn’t lubricate things nearly as well as fluid at operating temps. Having the fluid go thru the radiator cooler before going back into the trans ensures the fluid is close to engine temp.
Witha TH350 or 400 trans, if your working the trans really hard, probably having the cooler after the radiator is best. If your engine is always running warm, having the auxiliary cooler ahead of the radiator probably would make things easier on the engine temps.
4door!cutlass
March 27th, 2014 07:16 AM
