350 trans will not shift
What transmission does it have? If it is a 350 as in the title then check for manifold vacuum to the transmission modulator. From the picture it looks as though the TV cable is not attached as in an OD trans. Is it attached and is it definitely a 350 trans, not too common in that car.
Good luck!!!
Good luck!!!
350rocketmurderedout
November 12th, 2014 10:38 AM
