TH350 Inspection Cover Bolt Size?
Old Jan 4, 2020 | 09:05 AM
69_olds's Avatar
I have a 1969 Olds TH350 and need the bolt thread size for the converter inspection/dust cover.
Thanks!
Old Jan 6, 2020 | 07:10 AM
oddball's Avatar
Those holes get completely hammered over the years. They're supposed to be 1/4"-20. But I've had transmission that had 5/16" sheet metal screws shoved in there.
You'll have to see just how bad the holes are, and they might need rethreading and/or helicoil.
Note that most inspection covers, especially the aftermarket ones, have terrible fitment. Don't be surprised if it makes all kinds of noise when you fire it up. It usually takes me three tries or so. Install cover, start it, remove cover, cut away plastic, repeat. OE ones are better, but no guarantees.
Old Jan 6, 2020 | 08:21 AM
69_olds's Avatar
Makes sense. I will probably go with the 1/4-20 helicoil suggestion.
Thanks!
Will1971
Drivetrain/Differentials
Nov 2, 2019 10:07 PM
denf221
Nov 9, 2014 12:54 AM
Sarum
Oct 13, 2014 01:45 AM
RALLYE KID
May 5, 2013 05:50 AM
rustycragars
Nov 18, 2009 01:21 AM
