1959 88 Dynamic Holiday Sports Sedan Transmission
Old Aug 11, 2019 | 12:32 PM
lanthony2020's Avatar
What model Jetaway Transmission do I have? 1959 Do you check fluid cold, hot, engine on, engine off? Thx
Last edited by lanthony2020; Aug 11, 2019 at 02:06 PM. Reason: Additional questions.
Old Aug 12, 2019 | 07:51 AM
Tedd Thompson's Avatar
If you have 4 forward speeds (and you should if its a 59) it's not a two speed jet a way. You should check the ATF with engine at operating temp and at a idle... Tedd https://classicoldsmobile.com/forums...-manual-90635/
Old Aug 12, 2019 | 05:21 PM
Not a Jetaway?
Thx Ted. It is a four speed. Why do you think, not a Jetaway? Wondering if 300,314 or what version? Thanks, Lex
Old Aug 12, 2019 | 08:51 PM
Charlie Jones's Avatar
Phantom Phixer
The term " Jetaway " is confusing . Because Oldsmobile used it twice on two very different transmissions .
Olds first used it in their advertising and sales literature on the four speed "dual coupling " transmission built between 1956 and 1960 .
Then the term was dropped until 1964 , when it was used on the two speed automatic transmission built only for F-85 ( and Cutlass ) models .
As far as what model you have , give us the info on the tag attached to the side of your trans .
Someone may be able to de-code it .
Old Aug 12, 2019 | 09:16 PM
OLDSter Ralph's Avatar
Were the 56-60 Jetaway's the same during those years or was there differences ?
Old Aug 13, 2019 | 07:43 AM
As far as I know the cases were the same, some internal parts were upgraded.56 year had issues with soft parts but I think by 57 everything was resolved......Tedd
Tony85cutlass
May 30, 2015 09:50 AM
marxpups
Jul 11, 2011 05:44 PM
cowboy76
Jan 23, 2009 08:33 AM
jlkoldsman
Dec 7, 2008 11:51 AM
sbs4332
Sep 30, 2006 09:39 AM
