1st TH350 Rebuild
Old Jun 23, 2020 | 12:57 PM
ajr2820's Avatar
1st TH350 Rebuild
So I rebuilt my TH350. This was my first time doing an automatic. Is there a way to test my work without having to reinstall? I had zero issues and was surprised how easy it really was to complete. I just would hate to get everything back together and discover an issue.
Old Jun 23, 2020 | 06:49 PM
Assuming the end play is correct, and everything air checks ok (you did air check all the clutch packs?) chances are any problems will be valve body related
I use a 3/16 section of brake line on a blow gun to test things before the valve body is installed. Remove the rubber nipple, install the brake line using whatever fittings needed. Then you can bend the brake line to whatever shape needed to apply air to the various holes in the case. You may need to wrap the end of the line with electrical tape to get a decent seal.
Old Jun 24, 2020 | 05:46 AM
ajr2820's Avatar
I did air check everything as I went. All was good.
Old Jun 24, 2020 | 10:09 AM
If your able to air test the clutches assembled in the case, and hear them apply with a solid thud (you may get some leakage around the less than perfect seal between the blow gun and case) then any problem will most likely be fixed in the valve body.
Old Jun 24, 2020 | 01:17 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
The only other way to truly test a trans prior to installation is on a trans dyno.
Old Jun 24, 2020 | 01:41 PM
ajr2820's Avatar
I guess kinda the point of my post. Is it a common practice? Recommended?
Old Jun 26, 2020 | 10:06 AM
Define "common practice".
For full out race and heavy truck Allisons yes it's normal. Normal guys like us no. Just have to be really careful during assembly.
Large trans suppliers like TCI dyno everything going out the door for obvious reasons.
If you can locate a shop with a trans dyno and the cost is reasonable then why not.
1973CutlassS
Jun 27, 2014 02:52 PM
junior supercar
Jun 7, 2014 10:19 AM
cintr113
Mar 29, 2013 06:24 PM
dre
Oct 20, 2010 07:36 PM
thorpedo91
20
Jul 24, 2009 08:01 AM
