- 215 Olds Transmission Question
- 1959 Hydramatic, silly behavior, need advice
- T56, TKO600 5Speed, or 4L65E
- Roto Hydramatic oil cooler lines
- Rebuild or Swap?
- Torque Converter for 77 cutlass 350/350
- 54 Olds Super 88/Trans linkage adjustment questions
- Yolk stuck on TH350
- Chevelle/El Camino clutch and brake pedals
- Swapping TH350 for 200-4R
- 55 hydramatic dual range seal puller tools?
- New Guy Question..... TH400
- What size vacuum line to TH-400 modulator?
- Need 54 Olds transmission work done/reliable shops ?
- Best shift kit for a TH400?
- Speedo Gear Questions
- Jetaway to Turbo 400 68 Cutlass
- 400 console shifter cable bracket
- 67 power glide
- Transmission cable floor hole?
- 400 turbo id
- 1965 442 clutch problems
- Looking for a Soft clutch
- What does the kickdown affect on the TH350?
- 200-4r
- Powerglide refresh
- Bench Seat 4 speed shifter
- 63 starfire vacuum ?
- kickdown cable pics? '71 Cutlass, 350 trans
- Tcs solenoid
- TH350 Big Issues !
- Muncie 4-speed and back up light switch
- TH350 Leaking Yoke
- Shifter Linkage
- Installing lighter weights from the B&M TH350 Governor Kit?
- manual flywheel help needed on conversion
- What the heck did the HE 2004R come in?
- Transmission noise - help!
- Switch Pitch 400?
- 68 cutlass th350 speedometer housing
- Bellhousing Compatibility
- Transmission linkage bushing on frame
- Running transmission lines
- Correct cooler lines
- new pump and converter transmission still humming
- Torque converter recomendation
- hurst shifter
- slip yokes/tci auto streetfighter
- Console shift boot
- 70 Cutlass Supreme - transmission fluid question
- Speedometer cable question
- TH350 Drainback Issue
- borg warner fitting to a 455 oldsmobile
- Column shift linkage to cable?
- My 2004R trans is toast!
- 58 speedo cable leak
- 1971 442 Hurst shifter handle info.
- TH350 Dipstick length?
- 2004r
- Dextron VI
- Need advice on Trans problem
- Megawatts switch pitch questions
- 63 F85 Clutch Lever Boot
- Muncie first gear noise
- 1969 Cutlass flat top wagon with TH400
- Replacing the TH 350 tail seal
- Transmission trouble
- Manual Flywheel Question
- Need your input on this issue.
- th400 slow 2-3 shift
- Kugel Components Shifter Kit
- 3 speed swap in place of 200r4 delta 88
- non Olds. Transmission temp light comes on.
- Dual Pattern TH350?
- Why can't I find this, and is it a TCS switch?
- No Media: Turbo 400 Filter Change
- floor shifter sloppy
- Tremec 5 speed trans
- 58 98 No Reverse, Fixed
- 1962 dynamic hydramatic transmission
- Trans adaptor 1957
- 200r4 build for 455 or buy a different transmission?
- What 5 speed?
- 1967 OG turbo hydra_matic switch pitch
- Console gearshift detent button
- 64 starfire reverse issues
- OW transmission rebuild specs ?
- What's the easiest overdrive transmission for 455 with 3.55 rear?
- Slim Jim Hyrdamatic full of water
- Anyone Used Re-Make Shifter from www.hurstshiftersonline.com
- -6AN Transmission Line Routing
- Transmission not shifting into 3rd. Any ideas what to look for?
- Where are the letters
- rebuild ow trans/ buy new
- Abf
- TH 400 & Jetaway
- aluminum bellhousing
- Routing Trans Cooling Lines
- 88 Cutlass Supreme Lockup problem
- Disconnecting detent cable
- I Did It Myself (Hydramatic)
- syncing back drive linkage
- 1957 auto trans rubuild
- Anybody Used Hyraulic Clutch? American Power Train or other
- 76 cutlass 442 4 speed conversion
- Advice on clutch
- Shifter off 1967 M20---will it fit my 70??
- Stuck lightning rods 84 olds newbie
- Bought 1967 M20--need some small parts
- Cutlass Supreme 70 - Transmission question
- Transmission Upgrade Q's
- Found Muncie M20--I think. Will this swap into my 70 Cutlass?
- 455 - Putting a 2004-R behind it, what changes/parts are required.
- 73 El Camino 4 Spd Parts Swapped Into Automatic 70 Cutlass 350/350--Will It Work?
- ANY HYDRA MATIC (slim jim) GURUS IN HERE?
- Th425 no gears or anything when gears are selected
- Trans fluid leak -- 68 Delmont 88
- transmission shift rod? 71 CS
- Fixing TH350 Storage Leaks?
- turbo 400 paint
- Hydra-Matic Valve Body
- Slim Jim 10
- Jetaway vs Super Turbine
- 64 Cutlass transmission?
- jetaway trans
- Jetstar 700r4
- 1965 Cutlass - Need to replace shifter, but keep console
- Cutlass th350 floor shift cable...
- Clutch adjustment
- 71 Cutlass S Transmission suggestions
- I'll Do It Myself
- Seriously considering a 4L80E for the 88 CSC
- Turbo 400 trans mount spacers?
- Trans additives??
- Anyone have th350 firmer shift suggestions?
- transmission lines
- What Type of ATF?
- 61-63 f-85 Hydramatic TV adjustment tool BT-33-2
- What parts for 200 4R?
- trans fluid seeping from output shaft
- location of 64 trans lines
- 700R Transmission mount question
- manual to auto conversion
- JO Code T350 is 1969
- 1973 442 4spd interchange
- 200R4 Torque Converter
- 1st Gear in Lo '50 Olds
- trans change
- '76 5 Speed transmission
- Aluminum bellhousing
- TH350C Lockup Valve Operation
- M21 or M22 ?
- 1970 442 dual gate install
- 68 cutlass possible torque converter and power issue
- High performance 2004r
- Is an M20 Muncie 4 Speed the same for all GM Brands?
- Clutch disc diameter
- 4 speed shift rods
- correct speedo cable length '72 CS 350/TH350?
- TH 400 Leak
- Slim Jim transmission issues
- Transmission speedo gear
- Help finding the ID numbers 71 Olds SX
- 4 speed muncie leak
- 425 Flywheel Question
- Building a TH350 to handle torque
- Th400
- Torque Converter Recommendation TH 400 and 455
- Converter spacer washers
- Turbo 400 not shifting
- Rebuilt 62 F-85 Roto -5 leaking from vent
- Muncie 4sp.
- 71 cutlass dual gate cable
- TH350 rebuild kits + converters
- Hydramatic shifts not up
- TH400 leaking from lower coolant line
- Hurst shift rods
- T56 In Cutlass Wagon
- TH350 Gear Whine
- Installing trnsmission 71 cutlass auto
- Changing Shift points TH400
- TH350 kickdown cable to 330 Qjet
- Speedo gear leak
- 1965 TH400 Switch Pitch Adjustment
- Muncie M22Z
- Floor shifter help
- Jegs 10" Converter
- Anyone help me identify transmission?
- TH 400 Will It Fit Cutlass 455?
- Kickdown cable location
- 200r4 t.v cable adjustment
- what is a 64-65 muncie worth???
- Trans Kickdown Harness at the transmission
- Adjusting your switch-pitch transmission
- Chevy th350?
- Floor Shift console conversion
- modulator line routing
- TH350 Leak From Yoke Air Hole
- help with kickdown cable adjustment TH350
- 68 cutlass powerglide shift issues
- O-Ring Size for Detent Cable
- TH 350 Trans seal
- Adapting chevy bell housing trans
- ID year of my Muncie 4 sp transmission
- 1955 Hydra-Matic question
- 1961 starfire
- Th350 to manual trans swap 71 cutlass
- th350 to th400 swap
- th350
- th400 puked all fluid out
- 200 4R dimensions
- Shifter?
- Torque Converter for 455
- Pilot bearing adapter
- Correct speedo gear for 15" tires?
- 62 dynamic trans swap
- 62 Starfire kick down ?
- swaping out a Slimjim for a TH400
- 1976 omega v8 5-speed swap?
- Auto Floor Shifter
- 200R4 Speedometer gear swap
- 65 olds 442 clutch equalizer
- 68 cutlass S engine and trans swap
- 1966 442 Transmission Swap
- Slim Jim Throttle Valve link travel spec needed
- Cable Hole
- Shifter and linkage
- Another 200-4r TV cable question
- Transmission and Speedometer Questions
- Changing Vacuum to Distributor changed downshift
- Midwest Converters Review
- Quick question...
- Transmission oil level
- 69 350 transmission
- 200-4r cooler lines
- 2-speed jetaway dip stick leaking
- starter gear replacement need to remove trans ?
- Kickdown cable install for 67 330
- auto to tremec 5 speed
- 67 cutlass passing gear switch
- Shift shaft seal remover tool
- Four speed automatic question
- Th200-4r question
- Play in SlimJim slip yoke
- Help 49 oldsmobile Big Six
- 1963 F 85 Trans. Question
- ID an untagged TH400
- number on servo cover ?
- shifting
