What the heck did the HE 2004R come in?
Old Sep 17, 2017 | 05:18 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I found the decoder online but no application. It shows as a 84 model and has been rebuilt at some point, not a stock converter.
Old Sep 17, 2017 | 05:36 PM
I also pulled the pan on what I assume is the original TH350 from my 70 S. Very little crap inside, has a converter drain and a dual bell housing bolt pattern.
Old Sep 18, 2017 | 07:31 AM
Apparently the online "decode" resources only cover the popular versions (Monte SS, GN, etc). One source shows "HE" as "Unknown", so THAT'S helpful.
GM used these in a bazillion run of the mill cars like Fleetwoods, Deltas, and Caprice wagons. Likely nothing special.
Old Sep 18, 2017 | 05:02 PM
I could ask the wrecker, my wife picked it up for me. I am betting it is from a big car. I was surprised to see what should be the original trans from the 70 being dual pattern and not filled full of sludge.
Old Sep 19, 2017 | 06:06 AM
Of course, this one has a brown gear vs the black, will be slightly off with the green 10 tooth gear.The fluid is a bit dirty but not burnt. No sure if the wrecker cleaned the pan, if not, it is very clean inside. I am stealing the lock up kit, Hughes pan/4L60E filter, mount from the other trans, should be done tonight. I did both front and rear seals as well. No fancy ATF, just Dexron 3.
Old Sep 19, 2017 | 07:47 AM
texxas's Avatar
I have an HE code 200R4 I pulled from a Buick Le Sabre at the pick n pull but I don't know if it was original to that car.
Old Sep 19, 2017 | 12:08 PM
cdrod's Avatar
Rodney
'84 HE trans code
According to the TurboBuick site; an '84 HE is Caprice, DeVille, Impala, LeSaber, and Parisienne w/ V-8 305" 5.0L Canada. In '87 the trans code changed to HF for the same models. Hope that helps!
Old Sep 19, 2017 | 03:47 PM
That sounds right, hoping it shifts through the gears like it should.
Old Sep 20, 2017 | 09:58 PM
In and shifting. I had to use the Qjet 2004R TV bracket. Shifts through the gears quick but a stock trans will do that.
1974 Cutlass
Mar 11, 2024 06:19 AM
fiona72
Jul 8, 2010 06:51 AM
Charlie_brown
May 13, 2010 09:04 AM
70 cutlass s
Jan 1, 2010 06:19 PM
Modern Motoring
Dec 30, 2007 01:57 PM
