help with kickdown cable adjustment TH350
Old Aug 10, 2016 | 08:10 AM
76olds's Avatar
Hookers under Hood
I looked at the downshift cable adjustment in the 1976 chassis service manual. It says to hold the plastic sleeve with a 1/4 in open end wrench then rock channel locks holding the cable to adjust.
I cannot seem to adjust it nor get any passing gear/kickdown to work.
I have alot of play and can pull the cable way out while holding the plastic sleeve.
I don't want to pull the cable too far out unless thats the way to go with it.
Has anyone had success with this adjustment? How far does the cable need to be pulled out while holding the plastic sleeve?
Any input will be appreciated
Eric
______
Old Aug 10, 2016 | 08:14 AM
Pull on the cable until it stops gently, slide the plastic sleeve close to the pedal at its rest position. Let go and press the pedal all the way to the floor gently. Your done.
Old Aug 10, 2016 | 08:28 AM
76olds's Avatar
Hookers under Hood
The sleeve is very loosy loosie on the cable, I don't know what the 1/4 wrench needs to do . The diagram also shows a ball with a cable stop. Is the ball suppose to move as well ?
I tried moving the ball along the cable but it wont budge.
Now..If I'm understanding this correctly, I pull on the cable with channel locks until the cable can't come out any further regardless how far it needs to come out.
Old Aug 10, 2016 | 11:47 AM
76olds's Avatar
Hookers under Hood
I have about 3 inches of play when just pulling the cable out easy by hand. Does anyone know how much further I should pull on the cable before it self adjusts back?
Is their anything in the trans that is preventing it from kicking down?
Eric
Old Aug 10, 2016 | 11:59 AM
svnt442's Avatar
If there is no tension on the cable at all it might not be connected inside the trans.
Old Aug 10, 2016 | 12:02 PM
76olds's Avatar
Hookers under Hood
I have tension but not before I have about 3 inches of cable coming out from the fun pedal. Should I just put the channel locks on the cable and pull with the 1/4 wrench resting on the plastic sleeve? I could drop the pan and check if its connected in ther, will i need to remove the filter to get to it?
Old Aug 11, 2016 | 12:21 PM
76olds's Avatar
Hookers under Hood
I dropped it off at my buddies shop this morning, much better, I now have the passing gear back for $100.00
better than me crawling under the car haha.
Eric
Old Aug 11, 2016 | 12:23 PM
Did he show you how to set it?
Old Aug 11, 2016 | 12:24 PM
76olds's Avatar
Hookers under Hood
No I just dropped it off, he said he had to take the pan off and fix some valve and adjust the cable.
Al Sanchez
Feb 26, 2014 03:10 PM
dschallock
Jul 21, 2012 08:30 PM
yeahbuddy
Apr 4, 2012 09:54 AM
archerbob
Sep 12, 2011 01:29 PM
mark8918
Feb 6, 2009 09:34 AM
