Chevy th350?
Chevy th350?
Ok. Chevy trans has a different hookup than olds for Speedo gear. I assume I can simply swap tailshat housings to fix that. Also the Chevy has a tiny vacuum modulator and the olds has a huge one. Is it possible the Chevy needs the smaller one due to the stage 2 build or can I simply swap that over as well?
Use the modulator valve that came with the chevy trans.
What did this trans orginally come in? Model year,car/truck etc? I'll try to help. I don't see changing the tail housing is going to help you much. Just too much trouble.
I'm going to be blunt here, but I don't see trying use this chevy trans is going help you meet your goals. I get it, it was a good deal, but after dealing with the many issues like this, you're better off with the correct olds transmission and less headaches. Sincerely, I don't want to sound like an ***.
The trans was in a early 80' grnd national. Or is frshly rebuilt stage 2 with stronger internals and a shift kit. A friend had it and no use for it and I Got it for 600 bucks. The stock tranny in our car is worn out and needs rebuilding badly. Money wise we are at point of no return honestly for now anyway. Some st we will go to an OD tranny but have to make due with what we have for a year or so.
I assume I could? I have the trannyss sitting side by side on the floor so figured it would be quick and easy to just swap the tail shaft housings over real quick. I don't know what could be different between them. That's probably what I'll do.
