TH 400 Leak
Old October 30th, 2016, 08:52 AM
1969 Oldsmobile Cutlass S
RustyOlds's Avatar
TH 400 Leak
So overnight my Cutlass' tranny decided to start leaking much more. I think I've found the new leak. I don't really know what this part is, it's towards the back of the tranny across from where the speedo cable goes in. Anyways appears to be seeping out of a bolt. It leaks a good puddle or so over a few hours. What's the diagnosis on this and is it possible to fix without dropping the tranny? Also it appears tranny is leaking motor oil or something out of the inspection cover, any ideas on that?
RustyOlds is offline
Old October 30th, 2016, 08:53 AM
svnt442's Avatar
That's the governor cover.
svnt442 is offline
Old October 30th, 2016, 02:50 PM
RustyOlds's Avatar
Went ahead and bought a new gasket for the governor, hopefully that fixes it. Anyone have any ideas on the motor oil leak?
Old October 30th, 2016, 03:09 PM
Hookers under Hood
76olds's Avatar
Sounds like you have a rear main engine seal leak if the oil is coming from the trans inspection cover. Not an easy fix.
Eric
76olds is offline
Old October 30th, 2016, 03:18 PM
Olds Fever
CRUZN 66's Avatar
Eric
As Eric said, most likely a rear main seal... The only other area possible would be the rear cam plug, which isn't common, but is possible...
CRUZN 66 is offline
Old October 30th, 2016, 08:20 PM
RustyOlds's Avatar
Well looks like I might just let it leak then. If its the rear main that sounds like it may be a bit above my pay grade.
Old November 1st, 2016, 07:39 AM
RustyOlds's Avatar
Ok I had one more question. I am using Synthetic Oil. Would for any reason this make a seal leak. The car had non synthetic in it before and never leaked. Changed oil a few months ago and it might have been leaking ever sense.
EDIT: nvm answered this myself. Will be switching back to conventional oil this weekend, hopefully the leak stops or will most likely be pulling the engine.
dgreen
November 6th, 2011 09:40 AM
Gearhead442
January 27th, 2011 03:03 AM
sbFALL63
January 23rd, 2011 09:01 AM
sbFALL63
May 28th, 2010 05:45 AM
dynamic88
August 30th, 2007 11:43 AM
Quick Reply: TH 400 Leak
