-6AN Transmission Line Routing
Old Jun 2, 2017 | 02:45 AM
rkk69olds's Avatar
I am nearing completion on my 455/TH400 installation. I am using -6AN braided line for the transmission and am looking for pictures and suggestions on how to best route the lines.
Old Jun 2, 2017 | 05:04 AM
I routed my hoses up and over the right wheel well.
Old Jun 4, 2017 | 07:00 PM
I ran mine thru the frame. I welded a plate covering the hole where the factory fuel line was ran. I put 2 color coded bulkhead fittings to make trans removal much easier. There are short 18 inch or so line from the trans to the bulkhead fittings. The lines come out in the front thru a large hole in the frame right back d the bumper bracket. The biggest hassle was installing clips to keep the line out of the front coil springs.
Old Jun 5, 2017 | 05:54 AM
1968_Post's Avatar
Here's mine...
Old Jun 5, 2017 | 10:51 AM
cdrod's Avatar
Rodney
1968Post:
I'm going totally off-topic, but what brand are your AC hoses? Did you crimp them your self or have them made? Thanks
Rodney
Old Jun 5, 2017 | 11:20 AM
69455's Avatar
6 AN at trans, thru frame hole, around coil over, thru frame hole in front of radiator to cooler.
Tight, no pics, but it can be done nice and clean.
A lot like matt69olds
frozencaveman
Mar 10, 2011 10:32 PM
panovel
Feb 9, 2010 07:41 AM
dantana
Aug 21, 2009 10:58 AM
RAMBOW
Jun 9, 2009 07:33 PM
Gary Lagacy
Jan 24, 2009 06:35 AM
