Megawatts switch pitch questions
Old Jul 31, 2017 | 08:15 PM
Cutlass Fan's Avatar
I am not sure if the variable pitch strator is actually changing from high stall to low stall and visa-versa. How can I tell for sure? I checked my CSM but couldn't find anything. The trans shifts up and down nicely and otherwise seems to operates perfectly.
Old Aug 1, 2017 | 05:56 AM
If move the throttle linkage towards WOT with the engine off you will here a click from the trans. I was able to feel it actually shift while driving.
Old Aug 1, 2017 | 10:33 AM
The switch for the converter makes contact at two different parts of the accelerator throw - at small throttle opening and at W.O.T.
Old Aug 1, 2017 | 06:05 PM
Thanks Guys. I don't know where the "Megawatts" came from in the title, lol, I didn't type it in!
Old Aug 1, 2017 | 09:32 PM
Firewalker's Avatar
If you know where the kick down connector on the drivers side of the 400 towards the back is, with its one electrical pin/blade, then look there, because the switch pitches had a second pin right there.
65dynamic
16
Mar 11, 2015 07:50 AM
hotrodpc
28
Feb 12, 2015 06:06 AM
CroixDad
Mar 25, 2013 11:14 AM
|-K|=K
Sep 29, 2009 10:55 AM
coppertopgmc
Sep 17, 2007 08:28 PM
