1970 442 dual gate install
Hi got the dual gate kit from opgi no instructions go figure It scares me
How do I know were to mount shifter on tunnel apparently one screw lines up with stock which one ?
How do I route cable to trans ?
Do I need a special bracket to hook to trans some say yes some say no
I got great instructions on cutting console so set there
Help!! Thanks
Help!! Thanks
Here's a thread created by a member a few years ago to help install the dual gate. He included a lot of pictures and measurements so I think it will answer all your questions. Let us know if anything else comes up. John
https://classicoldsmobile.com/forums...dual-gate.html
would some please tel me which is the stock hole that the dual gate goes in as I dont want to screw this up AND
If your converting from a column shift to floor shift you will need to drill a hole and enlarge it to about 1" for the cable to go through. Its in that link 2blue442 posted.
I'm almost positive you will need a different bracket on the selector shaft of the trans. It is not in that kit. It needs to have rectangle slot for the tip of the cable to be retained. That slot is where you adjust the cable.
When I installed mine, I don't remember using in stock holes. Figure out where is sits best. Since this is cable operated, you can fudge it back and forth left or right, it don't matter.
I would mock it up, pick a spot on the floor temp mount the shifter and set the console on the brackets...Iirc the console mounting had some fore aft leeway like an 1/8th inch either way. The shifter needs to fit within a specific Area of the console
ARw30
Sep 22, 2013 08:23 PM
ah64pilot
May 29, 2012 03:04 AM
