How adjust neutral safety switch in 1970 olds 442 dual gate ...
Old Sep 22, 2013 | 02:14 PM
ARw30's Avatar
Hi there
How do i adjust neutral safety switch in 1970 olds 442 dual gate?
Can i use the same switch from none dual gate shifter ?
Old Sep 22, 2013 | 08:23 PM
svnt442's Avatar
The 70 dual gate has a unique switch and is not related to the standard shifter.
Finding that switch is almost impossible as I have not seen it reproduced anywhere so you'd need a functioning used one...good luck with that.
Another way you can go about it if you're not concerned with originality is to hook up a column mounted shifter switch as that's what was done in 71 and 72 anyway. It just uses the backdrive linkage from the trans to operate it.
oldspackrat
Nov 17, 2014 06:31 AM
mb893777
May 23, 2014 11:22 AM
bcf102
Aug 25, 2013 09:43 AM
footbrake
Jun 12, 2006 06:10 PM
oldsnut7098
Aug 10, 2003 10:06 PM
