Neutral safety switch?
Old Jun 4, 2006 | 06:50 PM
footbrake's Avatar
I have an 85 Cutlass and am trying to wire the neutral safety switch from my B & M shifter to it. Does anyone know which wires coming out of the column I have to tie into. I already did the back-up lights, but am having a real problem finding the neutral safety switch wires. Any help is greatly appreciated.Thanks-Russ
Old Jun 12, 2006 | 06:10 PM
Miss442's Avatar
if you have a digital multi-meter, in your ohms setting there is a setting thats called continuity, just unplug your wires put your positive on one end and take your negative to probe your other wires, you may have to use a jump wire to reach the other end. the first wire to make a beeping sound is the wire you are looking for.
miss442
oldspackrat
Nov 17, 2014 06:31 AM
Flye
Mar 30, 2009 03:45 PM
70 ctls
Jan 28, 2009 03:20 PM
OhMyOlds
Aurora
Oct 21, 2007 12:44 AM
oldsnut7098
Aug 10, 2003 10:06 PM
