High performance 2004r
Old Nov 18, 2016 | 04:40 PM
fly1's Avatar
Got ahold of a 2004r tranny from an 86 caddy fleetwood. KC valve body had a olds 307 engine. Will this be a decent core for a performance build.
Old Nov 19, 2016 | 04:31 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
It will be fine. Once bigger boost valves, slide spring, servo and a governor change or mod will make it act totally different. Higher line pressure is key. I have mine up to 215 psi in drive. It shifts completely normal under light throttle, floor it and nice firm shifts at mid high 4000 rpms happen. Your current governor may shift as low as 3000 rpm. The cheap governor PATC shifts at 4000 rpm, I have used it. Adding the green line bias spring from the big Trans Go kit increases full throttle shifts 300+ rpms. I plan on building my spare pump with all the goodies and measure the clearance this time to push closer to 250 psi when I put the upgraded 350 in front.
Old Nov 20, 2016 | 05:17 AM
fly1's Avatar
Ok thanks
Old Nov 20, 2016 | 08:41 AM
Firewalker's Avatar
Smile
Here are some videos on the transmission, including how to modify the governor if higher full throttle shift points are desired.
https://www.youtube.com/user/spikedp...arch?query=200
Lots of info on the net and boards. TexasT
https://www.google.com/search?client...utf-8&oe=utf-8
Jakeshoe
https://www.google.com/search?client...jakeshoe+200r4
Dan out of Florida
https://www.google.com/search?client...+florida+200r4
And for some more interesting info
http://highperformanceolds.com/phpbb2/viewforum.php?f=7
We aim to please
Old Nov 20, 2016 | 03:55 PM
Dan Mascal or Dr Dan as he is known, was a GM tech for years. He has built these trans for cars in the 9's including his big torque Olds 403 in the 11's. Grinding the governor is trial and error. Get a deep pan with a drain plug for ease, since the governor requires pan removal. Also anything with power needs the 700R4 or 4L60E filter and deep aluminum pan with it over filled. I am running that setup. If your goals are lower than 12's, the sheet metal pan with a rear/bottom feed filter.
Stevec
May 30, 2012 06:35 PM
67 Cutlass Freak
Dec 4, 2011 10:04 AM
Rocket_52
Jan 31, 2011 10:18 AM
wmachine
Dec 30, 2009 05:55 AM
bobgagt1.0
Jul 15, 2009 09:09 PM
