425 Flywheel Question
Old Oct 11, 2016 | 11:17 AM
MikeManer's Avatar
Would anyone here know if the factory flywheels for the 330/400/425 were made of nodular cast iron? Were these flywheels drilled for 10.5" clutches? Thanks for any help you can offer.
Mike
Old Oct 11, 2016 | 12:55 PM
Oldsmaniac's Avatar
The ones I have are drilled for both 10.5 and 11 inch pressure plates. I have seen a reported 64 330 with just one set of holes for the 10.5 clutch. As far as material I would guess they are cast? like most other stock flywheels.
Old Oct 12, 2016 | 07:17 AM
MikeManer's Avatar
Oldsmaniac, thank you for your help, I appreciate it.
Old Oct 13, 2016 | 07:08 AM
Run to Rund's Avatar
The ones I have seen had both bolt patterns for diaphragm/Borg and Beck type hats. Not for Long pressure plates. They can heat crack and can break up into pieces, especially if racing/high performance is in your plans.
Old Oct 14, 2016 | 06:12 AM
MikeManer's Avatar
Run to Rund, thank you for the information. It looks like I'll be needing an aftermarket flywheel.
Mike
NAS Backyard
Nov 22, 2013 09:42 AM
Flye
Jul 28, 2013 12:05 PM
therobski
Mar 14, 2011 04:38 PM
DennisG.
Oct 29, 2008 10:31 AM
