Replacing the TH 350 tail seal
Old Jul 27, 2017 | 08:18 PM
Oldssupreme's Avatar
Chris
Hi guys! I'm sorry if this seems like a very simple question but I want to make sure that I'm doing this correctly and don't mess anything up. Can someone please explain how to replace the rear tail seal on a TH 350 on a 72 cutlass supreme 350. I hope I'm calling it the right thing. It's the seal right before the driveshaft. Thanks guys
Old Jul 27, 2017 | 10:23 PM
You just need to pry the old one out and carefully tap the new one in.
Old Jul 28, 2017 | 04:29 AM
Chris
Eric, it's that easy???
Old Jul 28, 2017 | 05:16 AM
tru-blue 442's Avatar
Old School Olds
Pretty much that easy. I like to use a thin coat of silicone on the edge of the seal
just for piece of mind.
Old Jul 28, 2017 | 06:35 PM
Gary M's Avatar
So you jack up the back of the car and don't need to drain any trans fluid?
Old Jul 28, 2017 | 06:46 PM
Old School Olds
When you pull the prop shaft, you will want a pan to catch the fluid that will come out.
Old Jul 29, 2017 | 06:06 AM
Chris
Thanks Gary and Tru-Blu. I don't have any fluid in it yet since I reinstalled the trans. When reinstalling the seal what's the best way to tap it in To make sure it seats properly? Should I use a socket that's about the same size?
​​​​​​​Thanks!
Old Jul 29, 2017 | 07:03 AM
A socket or a piece of pipe.
Old Jul 29, 2017 | 07:45 AM
There's no fluid in since I reinstalled the transmission
That would have been the best time to access and replace the tail shaft seal. You might also want to consider changing the o ring for the driven gear sleeve while you're at it. It also is prone to failure and leaking.
Old Jul 29, 2017 | 10:39 AM
edzolz's Avatar
Be sure to lube the seal lip or lube the driveshaft yoke before you drive the car. Seals should never be left dry. They will burn up and leak.
Old Jul 29, 2017 | 11:37 AM
^^^This.
The preferred lube for automatic transmission seals is petroleum jelly. It sticks to the seal and will dissolve in the ATF.
70rocketpilot
Aug 4, 2018 06:10 AM
at3reg98
Jul 7, 2012 12:49 AM
W70442
Jul 22, 2011 06:55 AM
trackz man
Jul 17, 2011 10:08 PM
Sixoh
Aug 8, 2006 05:11 AM
