Converter spacer washers
Old Oct 6, 2016 | 04:56 PM
CJG's Avatar
CJG
Ok. Using the transdapt kit to bolt my 438 to a Chevy trans. The kit came with 2 spacer washers for the converter to Flexplate bolts. Its not enough. I have to pull converter completely into the crank boss to come right. I've read some reviews where some people have said they needed 3 washers on each bolt. My question is would it matter if the 3 rd washer was a lock washer? Its all I have around that's the correct diameter/thickness. I don't see why it would hurt anything, and maybe even help keep things tight.
Old Oct 7, 2016 | 06:40 AM
CJG's Avatar
CJG
Nevermind, found some correct washers. All is good I think!
Old Oct 7, 2016 | 09:09 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
When used a bell housing adapter and aftermarket converters, that need the gap filled, regular washers work fine.
Old Oct 23, 2016 | 12:31 PM
transman74's Avatar
The proper way is to have a converter built to take care of the bell housing difference.
We built a ton of converters for race cars that used a mid-plate. All we asked was the thickness of the plate and built the converter accordingly. This procedure was also done when someone had a transmission they were mounting to a different brand engine.
IMHO washers are a poor way to go.
Do it right - once
starfire
Aug 26, 2011 01:08 PM
matt69olds
Aug 4, 2010 10:23 AM
Ddbord
May 28, 2010 07:47 PM
nelsontj
May 5, 2010 05:30 AM
