- wont shift out of first
- torque converter help
- chevy th400 trans same as olds th400
- flushing transmission
- vacuum modulator
- Hydra-Matic 4S
- Dual Gate Top Plate Screws Needed
- Muncie Gear Oil
- 1968 Cutlass Transmission Conversion
- Roto-Hydramatic problem
- New Transmission Lines
- Speedometer!
- trans fluid level
- bell housing adapter
- detailed instructions
- sale at Auto Gear on Muncie parts
- "turbo hydramatic 350" = 350cui?
- 64 442 muncie gm tag Id
- 1970 Turbo 350 Trans - Pan Color
- Speedo inoperative
- 65 Original crossmember ...?
- Auto to manual
- Stock Aluminum DriveShaft Lenghts
- 65 Conv. (TH400)crossmember to frame...
- How does a 1980s olds cutlass floor shifter work?
- Checking transmission fluid
- 200-4r Yoke Problems
- 10 bolt posi vs 12 bolt
- Thumping sound when in gear but not N!!
- sell or scrap working 1964 jetway trans
- 200-4R shifting late
- T56 Manual Clutch Linkage For Buick Olds & Pontiac
- Centerforce Dual Friction versus DFX Clutch kit
- where to buy a th350
- Throttle Switch
- 62 Starfire Trans Noise
- fitting size
- What's special about OW W30 TH400?
- muncie 4 speed trans keeps poping out of 2nd gear.. why?
- TH400 shift points
- horrible tranny news
- what is better 2,500 or 3,000 stall
- 51' Hydramatic trouble
- My Tranny is only a 2 spd...Should I get a new one?
- 350 Turbo Slipping--Need Some Help Please
- cable routing
- Tranny Rebuild Costs
- Transmission for my '63 F85 215v8
- Jetaway (ST-300) Reliability?
- New M22Z with pics
- 400 turbo won't kick down
- 2-Speed (3-Stage) Jetaway Trans?
- Driveline stuck in tailshaft
- Th400
- Kickdown Cable
- Confusion about 2-speed Jetaway
- RotoHydramatic ( Slim Jim ) question
- Engine Removal - gear's locked up
- 4 speed hump
- Does this look like a shifting issue with my TH350? (Video)
- reproduction of 70 442 hurst shifters
- Leaking governor cover seal on 350
- Wanted: Hydra-Matic Transmission Tool Set
- Overdrive questions...TH200/700R4...
- !@&%$@ Slipping 350
- 70 olds 4 speed console shifter
- Pump 'n' Dump tranny service?
- '68 442 - Various Items
- torque converter lockup questions
- how do u lube the speedometer cable?
- TH350 to TH400
- 200-4R parts
- Transmission Identification?
- 72 Olds Cutlass Supreme-Tranny Pan
- Recommendations/Advice Needed Trans Swap
- 1972 Cutlass S Shifter Question
- 1967 442 4 speed shifter location
- BOP bellhousing for a T-56
- Know a TH 400 rebuilder near Western Massachusetts?
- 1970 442 manual trans
- Torque Converter problem
- Who wants a turbo 400?
- follow up...th350 now shifting!!! problem solved!!
- 200-4R will not down shift to 1st gear
- TH350 will not shift out of 1st!!
- hydromatic to jetaway?
- hydra-matic transmission problems
- Anybody familiar with the Doug Nash 4 speed?
- 1956 Help
- Picture of '50 88 trans linkage?
- how to remove the trans pump
- rear trans seal
- TH400 Decode?
- 66 Toro trans kickdown sw.
- how to adjust reverse light switch
- Casting Number For 4 Speed
- 700-4r
- new rebuilt t-350 doesnt do anything?
- Stall Speed
- Tranny Linkage
- Muncie Crossmember
- did my TH350 let go today?
- bolting up torque converter to 455
- TH 400 tailshaft swap
- 350 Transmission
- 1964 Super 88 trans swap with 1960 88 trans
- TH350 Vibration (Torque Converter)
- cooling line fittings missing?
- what did my trans come out of
- 56 Hydramatic kick down.
- 57 Hydramatic leaking
- 72 Cutlass auto floor shift conversion
- W30 Transmission problems
- New exhaust vibration causing trans fluid pan leak
- transmission ID problem.
- Floor shifter is sloppy
- ST 300 to a TH350 Swap!
- Cooling lines
- 68 VS 70 console shift gates?
- Arm-twisted into a frame off
- Having trouble finding replacement transmission cooling lines
- Jetaway to TH350 trans swap in 68 Cutlass
- 3 spd and 4spd shifter rods
- transmission id problem
- Question about transmission cooling lines
- Bolt Size??????
- spedometer gear hold-in
- 350 trans kick down
- Slim Jims served hot crispy
- Rebuild or not?
- 350 trans
- TH350 Shift Rod/Cable Help
- transmission leaks
- M22z anyone??
- TH350 Shift Cable/Rod (Help)
- Slim Jim damper plate - transmission
- TH400 dipstick leak
- 1967 TH400 Switch Pitch
- Trans Recomendation
- Flywheel cover
- TH400 leaking
- 4 sp clutch linkage?
- need some transmission cooling lines
- ST300 yoke
- Holding gear too long....
- Transmission parts
- Turbo 350 driving me mad !!!!
- so I have three problems...
- kickdown electrics needed?
- 72 cutlass th350 not shifting correctly
- Will this torque converter be ok?
- check out this sales pitch from local trans guy
- speedo cable houing leak
- Band Adjustment for 1963 RotoHydramatic (Slim Jim Transmission)
- th400 speedometer drive gear identification?
- th400-- measuring play on input and output shafts
- Help Jetaway & 350 Transmission Lines.
- Exploded view valve body th400
- TH400 rebuild questions
- ID tranny
- '65 wheel-driven speedometer
- How Do I Pick The Right TH350 For My `71 Delta ?
- Will an m21 hold up under a 425hp 455?
- 1955 hydra matic needs help
- th400 question
- Unknown wires above transmission
- Rear output shaft seal
- Correct way to check transmission fluid
- powerrglide
- new flexplate
- Torque converter
- Chevy parts are cheap.
- th350 mechanical shifting problem
- 1970 442 4 speed
- 1969 OW Trans rebuild help!! Need information!!
- 67 442 shifter cable...... Help!
- Need help with Flywheel choices
- Trans acting funny
- Th350 tranmission problem with 3rd gear
- tornado block with 4 speed?
- speedo help over drive to a 350 turbo
- Other Overdrives?
- help how to replace detent (downshift cable) on a 84 olds delta 88 with 200c trans.
- Looking for M20 or M21 Bellhousing
- What flywheel ??
- Mcleod M-800 5 speed
- 4 speed console shift handle
- 1970 Rocket 350 - Which 4 speeds were used??
- st 300 jetaway
- Jetaway Swap
- 455+st300?
- TH350 vs 200-4r vs 700-r4
- T-5 swap
- 70 Vista Cruiser Transmission
- Crossmember ?
- TH400 swap question
- Trans. ID.
- Losing fluid through the dip stick tube
- Help with speedometer reading and mileage
- Trans ID
- Torque Converter best fit
- M14 HD 3spd - Is the bellhousing the same as a muncie?
- New Idea: Electronic Overdrive 4L60e
- Bow Tie Overdrive 2004r
- Converting auto to manual
- TH350C pressure switch wiring...does it matter which is + and which is -?
- Kickdown
- tranny rebuild
- Can anyone help with my Jetaway problem?
- What transmission is this? ('81 Cutlass)
- Trans slipping!
- odorless smoke
- 455 flywheel part number?
- th425 OM w/factory stall conv
- HELP, with going into passing gear ?
- 4L60-E, 4L65-E Oldsmobile Bellhousing
- My New TH400 Compared To Slim Jim
- do I need a trans cooler?
- Opinions on this 200-4r
- 2 speed jetaway pitch/switch adjustment
- I need opinions and/or feedback
- 2001 OLDS AURORA trans
- 2004r dust shield hardware size
- sp th400 problems
- What part number and how to replace
- TH 350 OR TH400
- turbo 350
- 2spd jetway trans- switch pitch questions...
- 60 olds with 72 455 help with back up switch
- 62 F-85-need to know what trans?
- 41 olds transmission
- Help! Another Trans Question...
- kick down cable clip
- TREMEC 5 speed
- Do I Need a New Torque/Stall Converter??
- Anybody use the summit transmissions?
- Torque Converter Leaking
- switch pitch conversion
- Jetaway to TH350
- shiftworks cable
- TH400 Serial Number Plate
- 350 turbo stall converter question???
- 1956 Olds Jetaway slips in reverse only
- shift cable to shift select shaft question
- 57 auto transmission
- Th400 Long Shaft
- 200r4 or th700 in cutlass
- stall converter question???
- Auto to Manual Conversion Parts
- Slim Jim Parts
