how to remove the trans pump
Old Jun 6, 2010 | 05:24 PM
1973olds98's Avatar
I noticed the bushing needed replaced,,How do i remove the trans pump,,,
Old Jun 6, 2010 | 07:28 PM
1973olds98's Avatar
I got it,,,Rented a slide hammer from autozone...
What is the retaining pin for ,,It came out when i pulled the pump off..I see where it goes,,,Do i just push it back in or does something need to be lined up?. i can slide it right back in..If it goes right back in is it in there right...I mean can it go in wrong...
Old Jun 9, 2010 | 07:03 AM
What trans are you working on?
Old Jun 9, 2010 | 11:32 AM
1973olds98's Avatar
400
Old Jun 11, 2010 | 10:12 AM
The only retaining pin I can recall in a 400 pump is for the pressure regulator. Get a manual and study it.
Old Jun 11, 2010 | 11:17 AM
Be cautious when you service an automatic transmission. They have ZERO tolerance to dirt. Your workspace has to be very clean.
Old Jun 11, 2010 | 11:58 AM
1973olds98's Avatar
I figured it out in the manual...thanks every one,,,I have the pump seal,,,rear seal replaced..My work are was pretty clean i think,,,i was cautious not to let any dirt in...After i got each seal pulled and replaced I wrapped plastic around them so no dirt gets inside..I also relaced the filter and pan gasket,,
tommyd
Oct 3, 2023 02:24 PM
512Lac
Apr 5, 2014 04:10 PM
EightyEightCut
Jun 3, 2013 07:47 PM
KRICHEN922
Jul 1, 2010 09:17 AM
64Super88
May 15, 2010 07:24 AM
