Picture of '50 88 trans linkage?
Old Jun 11, 2010 | 06:39 AM
panamracer's Avatar
Hi Guys!
Would anybody be able to send me a picture of where the bracket for the trans. linkage mounts for a '50 Olds 88?
I just installed mine yesterday that I had sent from a junkyard; I have both rods attached, but cannot seem to figure how the bracket itself mounts.
I really would appreciate any help you could give me.
My e-mail is panamracer@hotmail.com
Thanks Much!
Old Jun 11, 2010 | 08:57 AM
You will need a service manual to set the throttle valve for your car. A picture is nice but this setting is CRITICAL. If it is a little bit off then you can fry your transmission. Maybe someone has some scanned directions for you. If not I suggest buying a Factory Service Manual and Chassis Manual. You can find them on Evil-bay from time to time or at suppliers like Fusicks.
Old Jun 11, 2010 | 06:24 PM
panamracer's Avatar
Thanks for the help, I had no idea it was that critical. I sure don't want to fry my trans.
Like you say, maybe someone will have that section scanned somewhere...hint, hint
Old Jun 13, 2010 | 01:10 AM
88 coupe's Avatar
Junior Member
http://edge-op.org/1949_Oldsmobile/index.php?page=341
From the '49 (Same as '50) manual: http://edge-op.org/1949_Oldsmobile/index.php#contents
Originally Posted by panamracer
........ I had no idea it was that critical. ........
It's not.
Back in the day, manual throttle control cables (lower pressures for street (or pits/return road) and higher pressures for competition were not uncommon. After some myths have been around for a couple of generations, they get accepted as fact.
Use the manual to get it in the ball park, then fine tune it to fit your own taste.
Norm
Old Jun 13, 2010 | 08:05 AM
panamracer's Avatar
Thanks, I really appreciate your help. I'll print these off and try to get it hooked up.
Thanks again,
Mike
Old Jun 14, 2010 | 05:52 AM
At least Norm had a link for you. Might as well set it correctly. It was my understanding that this was a critical adjustment. Good luck and keep us posted.
Rick67OldsVert
Oct 19, 2014 10:26 AM
Insom
Feb 22, 2011 04:44 PM
granddaddy-O
May 14, 2008 08:27 AM
sborruso
Nov 20, 2007 04:11 PM
<Cody>
Aug 10, 2003 10:00 PM
