Jetaway Swap
Old Jan 10, 2010 | 05:49 AM
kgenesse's Avatar
Jetaway Swap
I currently have a 1957 Oldsmobile 98 with a 1957 Jetaway. Does anyone know if it is possible to swap that transmission with a 1959 Jetaway? I realize the output ends of the transmissions would have to be swapped as well, seeing as the 1957 does not have a yoke at the transmission and the 1959 does. Are the output ends swappable?
Old Feb 12, 2010 | 11:35 AM
d2_willys's Avatar
Interesting that the 59 Jetaway has a yoke! You sure that someone just didn't slide it onto the splined output shaft? If all that is different and the yoke will slide off, I don't believe you will have much problem getting the newer unit into the 57. One note: you will NOT be able to push start the car with the newer transmission, NO REAR PUMP on the 59 and up JETAWAYS.
BTW: Where did you get the 59 Jetaway from, a 59 Olds? If so was it a Dynamic 88? If it was, is the engine available from the guy you got the trans?
Old Feb 12, 2010 | 11:44 AM
kgenesse's Avatar
The guy does tell me it is from a 1959 Dynamic 88. He no longer owns this car, however.
I highly recommend you call him, he is usually able to locate anything that I throw at him
Johnny Rosen
(602)569-1010
Phoenix, AZ
Old Feb 15, 2010 | 02:56 PM
d2_willys's Avatar
Johnny Rosen
(602)569-1010
Phoenix, AZ
Thanks, I will do that!
jerseyjoe
Jul 12, 2019 10:08 PM
68oldscutlass
May 15, 2013 04:41 AM
Sid
Sep 19, 2011 07:12 PM
billykissell
Jun 7, 2011 05:17 AM
dallas6778
Oct 15, 2008 10:59 AM
