flushing transmission
I had my TH-400 rebuilt, and I was wandering if anybody knows how to flush the ATF from the cooling lines. the lines go into the radiator then back to the tranny. Can I just put the air hose up to the line and all the fluid will blow out. Any help is appreciated.
thanks
bigwillystyle
thanks
bigwillystyle
You can buy transmission cooler flush in a can at NAAP or other good parts stores Hook up to cooler lines. The can is pressurized and will flush out old fluid. I have used this before and works well.
Oldsragger
January 25th, 2015 04:07 PM
