Tranny Linkage
Old May 20, 2010 | 02:43 PM
wami's Avatar
Tranny Linkage
I have a 69 Cutlass convert with a 455, TH400 and a Hurst dual gate. My problem is that I'm finding nearly impossible to adjust the linkage to be able to get park and low in the same setting. I had Hurst rebuild the shifter but am still having the same problem. I'm wondering if anyone has overcome a similiar issue? Could the tranny arm be incorrect?
Old May 20, 2010 | 04:42 PM
Boldsmobile's Avatar
Original cable being used?
Old May 21, 2010 | 07:11 AM
wami's Avatar
Hi Pete,
I'm not sure if the cable's original or not? Tinkered with it again last night and can now get park and low (after die grinding the hole on the tranny arm a little) but only 1st and 2nd on the right side of the shifter. It's out about a 1/4 to 1/2 an inch from getting all three. It's driving me nuts!
Just purchased a gear vendor and desperatly need all three gears. Any hints or tips would be greatly appreciated.
Old May 21, 2010 | 09:05 PM
4speed's Avatar
There are two different cable brackets ( mounts to the tranny pan ) one for 400 turbo and one for 350 turbo.
Old Jan 31, 2011 | 03:27 AM
72SDOlds's Avatar
Any Updates on this? I am having the same problem trying to get mine adjusted.
Old Jan 31, 2011 | 08:58 AM
wami's Avatar
Thumbs down
Ended up putting in a new cable and die grinding the tranny arm until it worked. Not necessarily what I'd recommend but being an extremely frustrated back yard mechanic at the time......it did the trick!
Old Jan 31, 2011 | 02:25 PM
don71's Avatar
same but different
Thats what I have done also after trying all the "correct" parts. My experience is the same as you?? Your method is what worked for me too.
Good luck to those in the future who travel this path.
Old Jan 31, 2011 | 03:07 PM
72SDOlds's Avatar
Well I am definitely in the frustrated boat. I also have bought all the correct parts, New Cable, brackets, linkage. Got a few ideas in mind, Die grinder is definitely one of them.
Old Jan 31, 2011 | 03:32 PM
Rickman48's Avatar
Try drilling another hole 3/8 to 1/2 inch up the arm, and connecting to that.
Seem to remember aftermarket arms having 2 holes!
dnmfranco
Nov 23, 2013 05:21 PM
crazy'boutOlds
Feb 4, 2012 06:06 PM
<jdhideaway@aol.com>
Brakes/Hydraulic Systems
Mar 31, 2005 08:15 PM
<Cody>
Aug 10, 2003 10:00 PM
