Trans acting funny
Trans acting funny
I got a t350 in a 84 cutlass supreme. My problem is that it only shifts from 1st to 2nd gear only and hard. When it does shift its @ about 25 mph. What can be the problem?
It would help to know that type of trans it is (TH350, TH200, 200-4R). As noted, if it's a TH350 with vacuum modulator, either the modulator is bad or the vac hose has come off. If it's a trans with a throttle valve cable, the cable is probably not adjusted properly.
navvet
Apr 18, 2011 05:38 PM
