Trans acting funny
Old Jan 25, 2010 | 07:50 PM
Eroc87's Avatar
Trans acting funny
I got a t350 in a 84 cutlass supreme. My problem is that it only shifts from 1st to 2nd gear only and hard. When it does shift its @ about 25 mph. What can be the problem?
Old Jan 25, 2010 | 11:40 PM
72 cutlass455's Avatar
Is there a vacuum line from the manifold to the transmission vacuum modulator check this out it is like a booster for the tranny when mine was not on my th400 it ran 3500 rpm in first.
Old Jan 26, 2010 | 07:49 AM
It would help to know that type of trans it is (TH350, TH200, 200-4R). As noted, if it's a TH350 with vacuum modulator, either the modulator is bad or the vac hose has come off. If it's a trans with a throttle valve cable, the cable is probably not adjusted properly.
Old Feb 5, 2010 | 09:02 PM
Eroc87's Avatar
Thanks guys but i couldnt find the vaccum modulator. i did find the throttle valve cable, how do i adjust it properly?
RustRocket
Sep 8, 2014 12:12 PM
oldsguybry
Jun 3, 2011 08:36 AM
navvet
Apr 18, 2011 05:38 PM
rocketraider
Oct 18, 2010 09:26 AM
bucknailer
Sep 15, 2006 12:55 PM
