1956 Olds Jetaway slips in reverse only
just bought this car and am getting the bugs out. it's been sitting awhile.
Got the brakes up today and drove it up to shift speed for the first time.
It runs and shifts great through all forward gears, But reverse slips with any uphill grade or resistance.
you can feel it go into and try to move while idling, but when you give it a little gas it just slips. I put it into reverse while it was jacked up to do the brakes. back wheels spun backward like normal. but with it on the ground, it slips. HELP and thanks shift pattern is PNDSLR
Try the oil and filter change. If no go, then either reverse clutch or piston apply seals for the reverse clutch have dried up. Good luck with the oil and filter change. BTW filter is about 65 dollars.
Tranny man said reverse cones were worn......(cone shaped rings) $250.00 in parts and $300 labor and were in bizness agin. Also resealed and no leaks now. Thanks for everyones input on this. case closed
Very reasonable repair, this guy didn't gouge you at all. Good deal!
Delmont 88 PA
September 17th, 2013 05:28 PM
rcdynamic88
August 29th, 2013 12:46 PM
