1956 Olds Jetaway slips in reverse only
Old Sep 7, 2009 | 08:18 PM
boogiel's Avatar
just bought this car and am getting the bugs out. it's been sitting awhile.
Got the brakes up today and drove it up to shift speed for the first time.
It runs and shifts great through all forward gears, But reverse slips with any uphill grade or resistance.
you can feel it go into and try to move while idling, but when you give it a little gas it just slips. I put it into reverse while it was jacked up to do the brakes. back wheels spun backward like normal. but with it on the ground, it slips. HELP and thanks shift pattern is PNDSLR
Old Sep 8, 2009 | 01:03 AM
Yellowstatue's Avatar
If it has been sitting a while maybe it needs the trans oil and filter changed
Old Sep 8, 2009 | 06:35 AM
boogiel's Avatar
thanks
that is on the agenda. was hoping to get some helpful info before dropping the pan
Old Sep 9, 2009 | 06:45 AM
d2_willys's Avatar
Try the oil and filter change. If no go, then either reverse clutch or piston apply seals for the reverse clutch have dried up. Good luck with the oil and filter change. BTW filter is about 65 dollars.
Old Sep 9, 2009 | 09:08 AM
IF you can't get a filter and pan gasket at Summit or a local auto parts store then Fatsco should have one.
Old Sep 13, 2009 | 07:08 PM
boogiel's Avatar
Thanks for all the replies. I took it to may tranny man, we'll know soon.
Old Oct 11, 2009 | 05:53 AM
boogiel's Avatar
Tranny man said reverse cones were worn......(cone shaped rings) $250.00 in parts and $300 labor and were in bizness agin. Also resealed and no leaks now. Thanks for everyones input on this. case closed
Old Oct 11, 2009 | 10:39 AM
citcapp's Avatar
Not quite closed, post some picture of you car in the vintage car forum for all of us 50's guys (others might like to look as well)
Old Oct 11, 2009 | 11:45 AM
boogiel's Avatar
Will do soon as the sun shows it's face again, so we can get some decent pics. Been cloudy and rainy for over a week here. thanks
Old Oct 12, 2009 | 06:48 AM
d2_willys's Avatar
Very reasonable repair, this guy didn't gouge you at all. Good deal!
Delmont 88 PA
Sep 17, 2013 05:28 PM
rcdynamic88
Aug 29, 2013 12:46 PM
dartphil
Jul 14, 2011 03:07 PM
bandit600
Dec 4, 2006 08:02 AM
