- 65 cutlass turbo 350 kick down
- Transmission cross member for a convertible
- TH400 2 in 3 Gear shift to late
- Best TH350 Rebuild Kit?
- TH 350 issue
- What's the name of this seal is it called the shift level seal
- Th350 WOT shift points?
- turbo 400 resistance on engine when in park
- 200-4r speedo gears
- 69 VC question
- Which Clutch Rod for a 455 in a 64 Cutlass
- TH350 Performance?
- Clutch recommendation
- TH 350 leaking, 71 Cutlass
- Turbo 350 what torque converter to use
- What Torque for Pan Gasket- TH200C?
- Torque Converter Value??
- Jetaway rebuild
- TH350 to TH400
- Factory Mod for 3 Speed?
- 2004r quality check
- Is This Possible?? 200-4R Tranny
- 1970 sx trans code
- Bop 400/t-56
- 1964 roto hydramatic a.k.a the slim jim
- Adding TH400 kickdown switch
- my 1969 odls f-85
- 200 4R Tranny Issue
- 2004r
- 1970 Cutlass TH350 won't engage
- torque converter
- To lock-up or not, 200-4r
- 72 Cutlass 'S' - Which O Ring / Seals for speedo gear
- Converting to manual
- Speedometer Delete Plug
- Gap between engine and bell housing???
- Tailshaft length
- TH350 to TH400, 72 Cutlass
- Crankshaft Questions
- Slim Jim/Roto Hydramatic
- Turbo 400 code
- Automatic transmission shifter locked up
- Th350-c
- Sealant Question
- 350 to 2004r swap crossmember
- Muncie rebuild
- 2004R issues
- Jetaway torque converter
- 1967 CS with Jetaway
- '69 Cutlass stalling when warmed up and put in gear or at long light
- Trans Tag Decal for '69 H/O
- auto to manual conversion
- Tubular transmission crossmember?
- 71 SX T400 clean up
- TH35 pan removal
- Transmission pan
- TH350C raising 1-2, lowering 2-3 shift
- Need a little help with Speedo driven gear change
- 1966 4 speed owners! I MAY have your trans!!! 6E175510
- Muncie ID help
- Which is inlet and which is outlet ?
- 4 speed trans problem on a 65 442
- 4 speed 1st gear ratios?
- Wide Open Throttle Shifts - 6,000 RPM Th350
- 200R4 Conversion - Tranny Mount
- 455 4spd
- speedometer woes
- 56 olds transmission bogging
- Flywheel ID please identify this one Thanks
- Can anybody tell me...?
- Rebuilding Olds Turbo 350
- TH425 Shift kit in 66 Toronado
- Need Reccomedations for Clutch/Pressure Plate
- Muncie
- 65 442 4 speed trans.
- Original or after market?
- Stock 403 vs Stock 200R4
- TH350 Kickdown
- Transmission Rebuild
- TCS switch on a manual transmission
- Transmission takes too long to shift
- Transmission Fluid Recommendations
- 2 Speed or 3?
- 10.5 or 11 inch clutch
- 455 flex plate
- 56 Rocket 88 not making 3rd
- Pilot Bearing
- 5 speed transmission
- should I get new TQ higher stall
- Needle in a haystack...
- Trans Temp Sending Unit
- TH350 in 70 cutlass supreme getting hot
- TH400 Vendors
- Would a '69 442 four speed have a console?
- does the olds 350 tranny have this electrical plug?
- I need help with trans selection
- Th350 kick down cable for 72 CS
- Learning the TH350
- 66 Cutlass S/P Wiring
- Turbo 400 I’d tag
- 1966 Cutlass 2004R swap
- 62 starfire
- H/O 4 speed Tranny
- TH400 questions
- 455 with 2004R
- 1972 Cutlass S 350 engine THM 350 transmission dipstick
- m21 shift bracket
- Transmission serial number
- th400 varible/switch pitch
- 700R4 question
- Slim Jim Transmission
- 66 442 shifter Opening in floor
- Output shaft
- Need a transmission guru
- Clutch Rod Length
- Clutch recommendations
- Is spacer needed for 55 hydramatic tailshaft seal?
- 84 delta 88 455 transmission
- Need 1968 4 Speed Floor Hump for Console
- 64 Cutlass trans woes
- 69 442 trans dipstick housing
- 54 Hydra-Matic output seal
- St 300 solenoid Cover?
- Servo Cover Decoding
- Turbo 350 or TH200?
- Different in Jetaway
- Early hydra-matic
- 4 Speed Shifter ID
- Hard to shift, park to all gears
- Trans ID help
- 1972 cutlass 350/TH350 kickdown switch installation
- Replacing Muncie drive gear - help needed
- Transmission to steering column linkage connection to frame
- TH 350 modulator pipe connection 1972
- 1967 Jetaway transmission swap
- TH400 build
- Why so costly?
- 200-4R vs TH400 | Old Threads - whats the current vote
- 1970 Cutlass Supreme TCS Solenoid Missing
- Speed when TH350 should shift
- Help with Hurst Shifter ID
- 455 oveheating
- Flexplate? SBO to 200-4R
- transmission change
- 200R4 Cooler line pressure
- Unknown transmission
- Got FITech and now having tranny problems
- '57 Super 88 3rd shift problem
- Help! Transmission leak
- Stupid bolt size question...
- 1954 Hydramatic.
- 1970 442 TC stall speed
- Shifter linkage
- Hurst shifter
- Split 394 from tranny??
- 1970 442 "OG" vs "OW" Transmission
- Transmission filter ?
- T-10 4 speed gearing 1962
- What year did Olds have the dual pattern Ford/GM bellhousing?
- 1962 Olds transmission swap
- Homemade GM Th trannytool
- Switch Pitch TH400 Rebuild
- Manual transmission options?
- '62 Starfire Slim Jim
- TCI or Monster Transmission 2004R TCC Lockup kit?
- Which flexplate?
- ST300 to 200R4 Swap gear ratio
- 1947 hydra-matic torus to flywheel gasket
- Help needed on Torque converter selection
- Separating the engine and transmission 1960 Olds
- slim jim roto 10 tv linkage on 2bbl
- 1965 vintage BW T-10 service
- TH400 pump rebuild issue
- New Solenoid, torque converter still not locking up on my TH350C
- ID for TH400
- Looking for a 71 Cutlass Supreme 350 rear main seal
- need dipstick for th400 72 cutlass
- Will a new torque converter improve acceleration?
- Hurst linkage/hdw
- ATF Fluid Level
- THM 350 Slow Drive Engagement
- Auto column shift linkage bushings
- Help me ID this transmission TH350?
- What type of fluid?
- Torque converter alignment questions
- Kickdown switch bad, yes?
- Rear seal leaking AGAIN
- Tightening TH350 trans cooler lines on 72 cutlass
- TH350C stall recommendation from Hughes
- 200R4 water contamination worry
- Anyone on hear go with gear vendors OD
- Transmission mount replacement
- Substitute for a roto?
- Which trans in 61 Super?
- TH350 Kickdown Cable
- Tailshaft Length
- throw out bearing
- Upgrade trans questions
- Barn find 69 olds 98
- BPO 700r4
- TH400 Shifter Cable Boot - 1968 442
- What transmission do I have in my Vista Cruiser?
- Any real way to know a junkyard th400 is good?
- Corvette 6 speed
- Bowtie Overdrives 200-4R
- Turbo 400 Kick Down
- Hardened Steel Bushing for Hurst Shifter
- 2004R for 500HP
- How common are dual pattern TH350's?
- Transmission leak
- 200-4R & Pressure Regulator
- Slim Jim reseal/refresh
- JetGlide Trans FYI
- Best fluid for a TH350C?
- th400 downshift question #2
- Mixing and matching TH350 gears
- 63 hydromatic slim jim - no pressure no move
- 1967 442 4 speed without console photo
- Speedo Gear Housing - TH350
- Muncie M 21
- from Jetaway to TH400
- Transmission Problems
- OEM Hurst shifter info needed
- Differences in th400 years?
- TH350 rebuild shop in Connecticut
- Hole in TH425 seal?
- Muncie I.D. and value
- 68 442 shifter handle #?
- Muncie conversion 1967 cutlass
- ST300/Jetaway only shifts manually
- Kickdown cable
- tci th 400 problem?
- Muncie side panel replacement help needed
- 200-4r questions
- 70 cutlass th400 long tailshaft
- Vaccume modulator leak
- TH400 Shift Question
- Decoding Numbers on a TH350
- T50 tranny swap
- Is this 455 Crank Ready for 4 Speed?
- Hurst quarter stick in factory 70 442 console
- Torque converter recommendations 200r4
- T5 Transmission Adaptation?
- Shifter linkage and identification
- Turbo 400 detail colors
- TH350 Modulator Vacuum Line
- Turbo 350 hard shift
- 4 Speed neutral safety switch information
- Mounting Hurst v-matic 3 in 69 convertible
