Speedometer Delete Plug
Old Apr 1, 2019 | 05:45 AM
ajr2820's Avatar
I've searched high and low and can not find one that says it fits the TH350. Anyone have any info on where I can find one? I can't believe that no one makes one. It's out of a 72 Cutlass if that makes any difference.
Old Apr 1, 2019 | 07:23 AM
Inline's Avatar
Just remove the driven gear from speedometer housing and tap it and install set-screw loctited there on place of that driven gear axle?
Old Apr 1, 2019 | 07:27 AM
Even easier: measure the diameter of the hole in the trans case, get an appropriately-sized freeze plug, and tap it in. Hint: use brass, not steel, to avoid galvanic corrosion.
Old Apr 1, 2019 | 08:13 AM
ajr2820's Avatar
Thanks guys. I just can't believe that with as many of these that are out there that no one makes one.
Old Apr 1, 2019 | 08:46 AM
Use a brass freeze plug. I THINK a 7/8 plug will work for the smaller bullet style.
ajr2820
Feb 6, 2021 09:23 PM
pfergy600
Feb 14, 2017 02:36 PM
irkennedy
Aug 10, 2014 12:17 PM
Napoleon1991
Jul 20, 2014 10:13 PM
35mastr
Jul 30, 2012 06:17 PM
