Th350-c
Old Feb 25, 2019 | 08:40 AM
young olds's Avatar
Th350-c
Anyone know how the lock up works on a 350c? I am taking the diesel out of my custom cruiser to put a gas engine in and want to make sure I keep the lock up functional.
Old Feb 25, 2019 | 03:42 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Yes, there is a pressure in the trans that locks up the trans at a certain speed. There also may be a switch attached to the break pedal that unlocks the trans. If should work fine with a gas motor.
Old Feb 25, 2019 | 06:38 PM
There is a 3rdgear pressure switch, and a brake switch on the gas pedal. You can wire it yourself, B&M makes a controller for the converter, Bow tie Automatic also makes one. Depends on how elaborate or cheap you want it to be
Old Feb 26, 2019 | 08:00 AM
young olds's Avatar
Ok thank you, I wanted to make sure there was no input from the engine that it needed.
Alaska442
Mar 14, 2022 05:10 PM
mais18
Dec 3, 2018 08:38 AM
firefrost gold
Nov 6, 2018 08:28 AM
brandon reynolds
Mar 30, 2018 02:02 PM
dele
Jan 19, 2017 01:14 AM
