Sealant Question
Old Feb 25, 2019 | 05:29 AM
WHIPOLDS's Avatar
Sealant Question
I have leak at the transmission dipstick tube on my 1956 Oldsmobile. Can anyone recommend a sealer that would work. I was thinking permatex.
Thanks,
Rick
Old Feb 25, 2019 | 06:49 AM
boese1978's Avatar
New o-ring perhaps?
Old Feb 25, 2019 | 07:29 AM
CRUZN 66's Avatar
Olds Fever
If the tube is loose, sealer will only be a temporary fix... Most likely it is an O-Ring issue as mentioned above and should be changed...
Old Feb 25, 2019 | 08:31 AM
2blu442's Avatar
I think in 1956 it was threaded into the pan, at least that's what the 1955 slantpan was. Long term it would be good to replace the tube if its damaged, what transmission does your car have in it?
John
Old Feb 25, 2019 | 08:43 AM
I agree with the others. Remove the tube and see if there's an o-ring that can be replaced. If the tube is threaded into the transmission perhaps it just needs to be cleaned and re torqued.
Old Feb 25, 2019 | 09:28 AM
WHIPOLDS's Avatar
Thanks for the suggestions. It is the Jetaway Hydra-Matic transmission. It is a tube that has a sleeve and a ridge. The tube is secured to a manifold bolt which broke causing it to come loose. I need to secure it but I was thinking of some type of sealer. I will check to see if it has an O ring. I really dread pulling the manifold to replace that bolt.
Old Feb 27, 2019 | 05:39 AM
Ozzie's Avatar
If I'm reading the parts book correctly, the 2nd type Jetaway used an "O" ring (part number 8617747) (0.725") on the filler pipe. I realize that dealing with that exhaust manifold can be a horrendous job, but you will have to do something to stabilize that tube or the vibration will continue to make a leaking problem. It would be nice if the manufacturers had used an anti-seize compound on all those exhaust manifold fasteners.
Old Feb 27, 2019 | 06:16 AM
WHIPOLDS's Avatar
Thanks Ozzie for that information.
Rick
falandys1002
Mar 12, 2016 05:49 PM
yalikeme
Aug 29, 2015 11:51 AM
.Rocket.Man.
Jun 27, 2015 07:24 PM
Charles Ludwick
Jan 27, 2012 06:59 PM
Mongoose
Dec 3, 2009 09:09 AM
