Sealant Question
I think in 1956 it was threaded into the pan, at least that's what the 1955 slantpan was. Long term it would be good to replace the tube if its damaged, what transmission does your car have in it?
John
John
Thanks for the suggestions. It is the Jetaway Hydra-Matic transmission. It is a tube that has a sleeve and a ridge. The tube is secured to a manifold bolt which broke causing it to come loose. I need to secure it but I was thinking of some type of sealer. I will check to see if it has an O ring. I really dread pulling the manifold to replace that bolt.
