repair motor
Old November 29th, 2018, 03:00 AM
repair motor
I am repairing my oldsmobile from 1949 (big six)
can anyone give me the repair dimension piston and bearing?
thanks
sorry for me english
mais18 is offline
Old November 30th, 2018, 08:25 AM
Hello
the restoration of the engine being too complicated, I think put another engine, what kind of engine can I put.
thank you for your answers
mais18 is offline
Old November 30th, 2018, 08:51 AM
Do you know what the problem is with the engine? Has it been disassembled, if not a compression test should be done and an oil pressure test.
I do not fully understand the question asked. Are you asking what oversize parts are available or are you asking what the clearances (distances) between the bearing and the crankshaft and the distance between pistons and the cylinder wall?
Bonne Chance!!!
Sugar Bear is offline
Old November 30th, 2018, 09:29 AM
the problem is in FRANCE when a person owns an American car, he thinks that it has a lot of money, because here to rebuild the engine I am asked $ 15000.
the engine problem it's just a cylinder with no compression
mais18 is offline
Old November 30th, 2018, 10:52 AM
Is it disassembled? Do you know the cause of the no compression? Rings, pistons a valve? What is the compression reading/pressure?
Often this can be repaired without a complete rebuild if the problem can be diagnosed properly.
Forum can guide you well.
Old November 30th, 2018, 04:28 PM
Oh no, not again...
Nailheadcanuck's Avatar
Location: Sherwood Park, Alberta, in the Great White North
La meilleure chose à faire est d’obtenir d’eBay un manuel d’entretien Oldsmobile pour le modèle 1949.
Il y a de fortes chances pour que le joint de culasse soit défaillant ou la soupape d'échappement.
Aucun autre moteur ne tient facilement dans cette carrosserie, à l'exception d'un moteur V-8 Oldsmobile; toutes les autres nécessiteraient beaucoup de modifications de cadre.
Nailheadcanuck is offline
Old November 30th, 2018, 09:18 PM
Tedd Thompson's Avatar
Ya, what he said..... Tedd
Tedd Thompson is offline
Old December 3rd, 2018, 08:38 AM
FuturamicOldsmobile's Avatar
15,000 to rebuild a straight 6? Are you out of your mind
FuturamicOldsmobile is offline
Allan R
August 1st, 2017 07:35 AM
BLACKCADDY
June 2nd, 2015 09:38 AM
OLZ442
October 24th, 2011 07:38 PM
dre
December 1st, 2010 09:20 AM
ctrain22
May 20th, 2009 11:02 PM
Quick Reply: repair motor
Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
