200R4 Conversion - Tranny Mount
Old Dec 21, 2018 | 05:35 AM
Tuffnut's Avatar
I have converted my 75 cutlass 350 from a Th350 to a 200R4 tranny.
I am in the process of checking the drive line operating angles because of some vibration I have over 70 mph,
With a used double hump cross member installed in the TH400 location, what is the proper transmission mount to be used?
Currently I have a universal mount from the transmission rebuilder who beefed up the tranny.
Changing so many things, I not sure where I should be height wise. Only thing I can go by is the operating angles. I don't want shim if I have the wrong mount in.
Does the 200R4 & output shaft sit at the same height as the TH350 ?
Does the dual hump crossmember mount location sit at the same height as the single hump crossmember?
Currently my engine is tilting down at 3.5 deg.
New motor mounts installed from Supercars #48-006
Jeff
Old Dec 21, 2018 | 11:58 AM
old80cs's Avatar
For what it's worth, I swapped a 700R4 in place of the TH350 in my 80' Cutlass Supreme with an Olds 350. I replaced the trans mount with a stock TH350 mount. Never gave any problems. I used stock engine mounts just in case that matters.
Old Dec 21, 2018 | 05:13 PM
I would think the output shaft and trans mount would be in the same location on either setup. If the angles are within specs, turn the driveshaft 180* on the rearend flange. You could also try to reclock the converter on the flex plate. There are 3 possible mounting locations, sometimes rotating the converter can help. Even if everything is in balance, the tolerances can stack up between the converter,flywheel, driveshaft, rearend, Tire’s, etc and cause a vibration
Old Dec 21, 2018 | 05:36 PM
Tuffnut's Avatar
Thanks for the input guys, I was going to mark the driveshaft before I remove it and offset 180 at the rear end. Also will do the flex plate as well. Easy to do once you are under the car.
I'm going to replace the front u-joints again and change the yoke with a spare I have. Check the angles and go from there. I was worried the heights may be slightly different between crossmembers and tranny's.
racintj
Sep 9, 2019 12:22 PM
Tuffnut
Jun 12, 2019 03:58 PM
70cutty
May 18, 2016 10:08 AM
car_designer
Mar 10, 2014 07:30 AM
1968ragtop
Jul 9, 2011 07:33 PM
