62 starfire
Old Sep 11, 2018 | 12:41 PM
Oldpac62's Avatar
62 starfire
Can someone show a pic of trans linkage on 62 starfire slim Jim please thank you
Old Sep 13, 2018 | 09:23 PM
Charlie Jones's Avatar
Phantom Phixer
Sure ;
Old Sep 14, 2018 | 07:36 AM
Oldpac62's Avatar
Trans
Charlie I thank you so much that showed me that my rod 4.035 has been bent ,probily non repairable will try .if someone has one I would like to buy it. Charlie is there any way you can send me the pics of the vac syst under the hood the other owner had things all messed up and I am trying to fix it all. It has been a challenge to say the least thank you Mel
Old Sep 14, 2018 | 11:16 AM
Phantom Phixer
Which rod is bent ?
There are two rods in the illustration marked 4.035 .
One runs from the shift lever to the bellcrank .
And the other runs from the bellcrank to the transmission lever .
I'll try to find some vacuum hose illustrations .
Old Sep 14, 2018 | 11:50 AM
Oldpac62's Avatar
Trans
The one that runs from side of trans to bell tower it is parallel with trans it has adjuster nut on it
Old Sep 14, 2018 | 12:33 PM
Phantom Phixer
If the car has A/C this would be the one . If not , let me know.
Old Sep 14, 2018 | 03:09 PM
therobski's Avatar
Hey Charlie, don't the A/C and Summer ventilation vacuum lines run of the fuel pump? The fuel pump provides the vacuum correct?
Old Sep 14, 2018 | 03:47 PM
Phantom Phixer
Yes , It was a combination fuel and vacuum pump .
Old Sep 14, 2018 | 06:00 PM
Oldpac62's Avatar
Vac lines
Charlie, I don't have air thank you.
Old Sep 14, 2018 | 07:34 PM
therobski's Avatar
OldPAC62 with or without A/C the vacuum lines for your summer ventilation actually off of the correct fuel pump. Do you see a vacuum line off the fuel pump running towards the firewall??
Old Sep 14, 2018 | 10:10 PM
Phantom Phixer
OK , then this one is what you need ;
huggie
Jun 15, 2018 09:42 AM
mikeolds
Jun 12, 2017 06:28 PM
Gasolinesmellsgood
Sep 25, 2014 07:46 AM
car fan
Sep 7, 2010 06:43 PM
tpawlik
Aug 5, 2009 06:31 AM
