Would a '69 442 four speed have a console?
Reading an article that says the optional transmissions for the '69 422 included (among others) a "4 spd manual close ratio Hurst floor shifter" as well as a "floor shifter optional on auto with console". Does this mean only the automatic came with the console and the manual transmissions did not?
If you ordered RPO M40 automatic trans, you got the 325 HP version of the 400 motor and a column shifter with either buckets or bench. You again had to order RPO D55 along with M40 to get the AT floor shifter and console if you had bucket seats.
It's all spelled out in the SPECS booklet.
FYI, in 1969, there was only one shifter and stick. It was the same with or without a console and with buckets or bench seats. The only difference was the rubber boot that went over it.
