What Torque for Pan Gasket- TH200C?
Seeking some assistance in reference to torque specifications for the TH200C Transmission Pan Gasket. Changing the fluid, filter, and gasket Friday. Technical specs show 6 to 10 FT. Lbs. What would be the correct torque or should I just tighten by hand? All replies are appreciated. And, should I insert a grade 5 ceramic magnet which was part of the original set-up?
Most people don’t own inch pound torque wrenches, and a lbs-ft that will accurately read that low is even less common. You want to compres the gasket enough to prevent fluid from wicking around the gasket, but not so tight as to split it or compress completely. I guess GM felt 6-10 lbs would be sufficient to accomplish both.
Basically use a 1/4 drive ratchet tighten till snug and then a little. If it weeps, tighten another 1/4 turn until it stops. Try to get them all so that they are somewhat even, as stated above 6-10 ft lbs is not much. "Felt" is a term like "being confident", not a gasket material.
* What of the gasket material, "Would that factor into torque specifications"?
For the record, there was a gasket manufacturer that used to do business under the name "Felt Products." They shortened that name decades ago. Now they're doing business as Fel-Pro.
Might be a good idea to calibrate your wrist by using the torque wrench, to see what 6--10 ft/lbs feels like.
No.
Thanks much. Great idea, never thought of it wrist to calibration. Anyways, it's done, just used a 13 to snug up the bolts. One corner seeped a hair near the front transmission cover but tightened up a bit more and fine. Would it not stand to reason that the gasket material would factor into the torque specs, seeing that cork is different than rubber and fiber also consists of different properties? Your 'no' seems quite certain.
No.
Bolt torque is based on all sorts of factors, among them the strength of the female threads--in this case they're soft aluminum and with less-than-optimum thread engagement. Similarly, the sheet-steel OEM trans pan is thin, thin, thin. Over-torquing distorts the pan, stresses the trans case threads, and may even push out the gasket.
So...NO, you don't need to dick with the torque spec when using a different gasket.
