Tubular transmission crossmember?
Old Jan 25, 2019 | 01:23 PM
Does anyone in readerland know of a company that makes a tubular trans crossmember that will drop straight down, as opposes to sitting inside the frame? With the big exhaust, gear vendor, and driveshaft loop it’s a pain to remove the crossmember. I have considered fabricating something, but my fabrication skills aren’t my strongest talent. I figure this will require welding a bushing or sleeve to the frame, and using a long bolt, kinda the same setup as the control arms.
btw, 69 Olds Cutlass, th400 trans. Thanks
Old Jan 25, 2019 | 02:52 PM
Summit?
https://www.summitracing.com/search/...odel/CHEVELLE/
Loops
https://www.summitracing.com/search?...veshaft%20loop
cstalnaker
Jun 14, 2018 06:44 PM
johns65442
Feb 1, 2014 10:52 AM
Frank3
Oct 1, 2012 07:28 PM
64 CUTLASS KEN
Dec 12, 2010 11:14 PM
Charlie_brown
Feb 11, 2009 11:27 AM
