Hard to shift, park to all gears
Old Aug 8, 2018 | 09:04 AM
yellowone's Avatar
I have a 1972 Cutlass Supreme. It is very hard to shift from park to all gears and back. It is a column shift three speed 350 trans. It almost has a metal scrapping sound when going from park to other gears and back. Need help diagnosing and possible r&r to repair if possible.
Old Aug 8, 2018 | 09:06 AM
442fanatic's Avatar
Check the linkages from the steering column at the fire wall that drop down to the driver's side linkages on the TH350 transmission. A bent linkage perhaps.
Old Aug 8, 2018 | 10:32 AM
It could be the linkages or it could be the column itself. Visually inspect the linkage for worn areas. Temporarily disconnect the linkage from the column arm and try moving the column shift lever through the gears. If it still scrapes, the problem is internal to the column.
David DeCan
Jan 23, 2016 09:10 AM
oldsmobilty
Jan 19, 2014 11:03 AM
Bitburger
Dec 30, 2012 04:49 PM
scott_442
Aug 10, 2011 06:17 PM
tarheeldoc
Jun 5, 2009 11:38 AM
