56 Rocket 88 not making 3rd
Old Oct 25, 2018 | 10:32 AM
zach66bonnett's Avatar
Hi all, hope you’re all well?
Question if I may, my Rocket 88 was making it into 3rd but now not. Oil levels for trans is fine ... wondering if anyone had the same?
Best wishes from the UK
Zach
Old Oct 27, 2018 | 08:12 AM
Tedd Thompson's Avatar
Is this a new problem? Are we talking about a slant pan or a jetaway? Has the car sat for a extended time? Is it acting as though it is in neutral when it goes into 3rd? Is it skipping 3rd and going on to 4th or only going through to second and stopping there? Have you tried adjusting the throttle / transmission linkage yet? We kinda need more detailed information to give you anything but a wild *** guess . That being said my wild *** guess would be a bad leaky valve body or a stuck clutch piston that is stuck in the release position or incorrect throttle to transmission linkage adjustment . It could be many other things though..... Tedd
Old Oct 27, 2018 | 12:04 PM
If it’s a Jetaway transmission, no shift into 3rd is normal. They are 2 speed transmissions, there is no third gear.
Old Oct 27, 2018 | 07:52 PM
Ozzie's Avatar
If it's the 88 series, then it's most likely not the Jetaway, but as Tedd said, we need to get much more information from the owner to try to do a diagnosis. And for 1956, whether it's Jetaway or the older Hydramatic, both transmissions had four speeds.
Old Oct 27, 2018 | 08:30 PM
Early first generation jetaway's were and are 4 speeds. The confusing part is the same transmission name but completely different transmission.I have no idea why Oldsmobile did that. People have been confused for sixty years and counting..... Tedd
Old Oct 28, 2018 | 04:12 AM
ignachuck's Avatar
Frank Ignachuck
Well, on my 56 Jetaway you can't feel first to second or third to fourth. You can feel the fluid coupling from second to third. So if you don't have third, you don't have fourth. The fluid coupling is the problem. Rebuild time.
Old Oct 28, 2018 | 04:27 PM
Bfg's Avatar
Bfg
And the Jetaway was often confused with the power glide!
Old Oct 28, 2018 | 05:03 PM
redoldsman's Avatar
Proud Viet Nam Veteran
If it is the later model Jetaway it is confused with the powerglide. Not so for the first jetaway that came out in 1956.
Old Dec 3, 2018 | 02:10 PM
classicmuscle442's Avatar
Zach, does the trans have a park position or do you leave it in reverse when parked?
Chips56
Dec 15, 2018 07:39 AM
TRWham
Apr 11, 2018 10:37 AM
cmpcpro
Nov 22, 2016 07:23 AM
rket56
Dec 28, 2013 09:27 PM
jaymann
May 10, 2010 03:01 PM
