Turbo 400 Kick Down
Old Mar 26, 2018 | 11:59 AM
RonFX's Avatar
Turbo 400 Kick Down
I have installed a Turbo 400 trans in my 66 Cutlass, I need to figure out how to get the kickdown to work. Has anyone been thru this before. The Acc. pedal pivots from the floor. I would prefer to use some sort on OEM setup if possible, even if I need to modify an original part so it looks correct and works good.
Thanks for your input
Ron
Old Mar 26, 2018 | 12:02 PM
Did you have an ST300 in there before? If so you can use the switch on the firewall to work on the t400 as well.
Old Mar 26, 2018 | 12:06 PM
RonFX's Avatar
The car originally a 4 speed car, there is nothing there as far as anything OEM
Old Mar 26, 2018 | 12:09 PM
This was in the classifieds:
https://classicoldsmobile.com/forums...nsmission.html
Old Mar 27, 2018 | 05:48 AM
That will work. The Jetaway and the 1967 TH400 both used the switch on the linkage bellcrank. That's a bolt-in for your car. Alternately, if you don't want to swap that out, get a 1964 style switch that goes on the intake and connects to the carb linkage.
toymobile
Aug 9, 2015 09:08 AM
oldspackrat
Mar 30, 2013 04:57 AM
MN71W30
Jan 25, 2013 06:43 AM
JOHNNYOLDS442
Jun 19, 2012 06:31 AM
cutlassjoe
Oct 14, 2011 04:41 PM
