Output shaft
The interesting factoid that I just noticed on that chart is that the light duty TH375 only came in the long tail (OK, technically, the medium "mamma bear") length. Makes sense, as the TH375 was only used in the small block powered B-bodies and Vistas prior to release of the TH350.
