does the olds 350 tranny have this electrical plug?
Hello everyone. I have a 1967 cutlass with a stock automatic floor shifter and 350 tranny out of a 1975 cutlass and was wondering, Does it have the electrical plug that connects to the shifter so the reverse lights will turn on when needed. If not do I have any options
Except for those used in the 1970-72 cars with Transmission Controlled Spark.
On top of the steering column on column shift cars and on the shifter on FACTORY floor shift cars. Of course, if the car was converted to floor shift or has an aftermarket shifter, chances are it was never hooked up.
The reverse lights are operated from the neutral safety switch, but I don't know where that is on a 67.
Yes sir. My tranny is out of a 1975 cutlass th350 in a 1967 cutlass. And i have a stock oldsmobile automatic shifter. The neutral safety switch is screwed to the shifter
There is a two-wire connector. The green wire with white stripe is powered with the key on. The light green wire runs to the backup light bulbs.
