Need a little help with Speedo driven gear change
Old Jan 14, 2019 | 12:07 PM
Minnesotajeff's Avatar
1972 Cutlass, TH400. I'm changing rear end gears from the stock 2.73 to 3.08's. Currently, it has the stock 18 tooth drive gear and a red 37 tooth driven gear. According to a chart I found online I THINK all I need to do is go to a 42 tooth Green driven, which also requires replacing the driven gear housing to one that accommodates 40+ tooth gears. I'm looking for verification on this, hoping someone else who has swapped rear end ratios has already figured this out.
thank you
Old Jan 14, 2019 | 01:08 PM
11971four4two's Avatar
MOTORHEAD
HEY THERE
I would just leave the speedo gear that came with the 2.73 in the car. there will be "virtually" no difference in what the Olds speedometer reads
That is unless you also changed the tire size as well
All the Best
brian
Old Jan 14, 2019 | 01:57 PM
Really? I've re-geared a lot of cars over the years and I've always had to change out the speedo gears to correct the reading. Are you suggesting that because the change from 2.73 to 3.08 is minor?
Old Jan 14, 2019 | 02:18 PM
MOTORHEAD
Yes
IF it were a drastic ratio difference I would tell you to swap gears etc for speedo
Check speedo with GPS
IF all was accurate and working with the speedometer before it will only read slightly different with 308 gear from 273
are you running factory size tires??
Old Jan 14, 2019 | 02:33 PM
yep, stock size tires
Old Jan 21, 2019 | 11:57 AM
Upon further research and calculations, i determined that my speedometer would read 8mph high with the gear change. so to be travelling 60mph I would need to run with my speedo at 68mph. It turns out in my drawer of speedo-gears that I've collected over the years I have the gear, just need the housing which isn't expensive. Got my diff rebuilt this weekend, gears set up with a really nice pattern and did new wheel bearings and seals at the same time. Now to wait until spring to actually drive it.
Old Feb 4, 2019 | 08:26 AM
boese1978's Avatar
Who did your rear gears for you? Can I ask what it cost you? I am set to go to a shop nearby to have this done. What part of Minn?
Thanks!
Old Feb 4, 2019 | 08:40 AM
TripDeuces's Avatar
There is an 11% difference between 2.73 and 3.08.
Old Feb 4, 2019 | 08:58 AM
I did them myself. I've set up several of the GM corporate 8.5" rears over many years. My first few were definitely learning experiences, but once you figure it out and have all the right tools it really just takes patience. I spend at least a couple days taking my time to do it right. Lots of trial & error to get the right pattern. Plus I have a lift in my shop which makes it a heckuva lot easier on my 53 year old body compared to laying underneath the car like I first did them in my 20's.
Docs72
Oct 8, 2019 08:02 PM
jpc647
29
Sep 8, 2017 09:02 PM
Redbud40
Jul 1, 2014 05:28 AM
delta254
Drivetrain/Differentials
Oct 18, 2012 10:11 PM
Beltman
15
Oct 14, 2010 04:10 PM
