1965 vintage BW T-10 service
Old May 26, 2018 | 10:54 AM
robert v's Avatar
Hello,
I need to have my Borg Warner T-10 4 speed rebuilt.
There is a hollow rattle noise internally when the drivetrain is engaged.
Like something is loose rattling around inside the case.
The noise is not there if the clutch is pressed to the floor.
I'm looking for recommendation for shop to rebuild Long Island N.Y.
Thanks,
Robert
Old Jun 5, 2018 | 01:24 PM
2oldsguy's Avatar
Larry is the best to deal with.
Transmission D & L
180 W. 19th St.
Huntington Sta., NY 11746
(631) 351-4837
Old Jun 5, 2018 | 02:57 PM
SmirchIs#1's Avatar
Originally Posted by robert v
Hello,
Thanks,
Robert
I build std. transmissions & I second the motion for Larry from D&L.I buy rebuild parts from Larry,great guy
Old Jun 5, 2018 | 04:27 PM
oldsconv's Avatar
Y
I know you can't "third" a motion, but I agree. Larry from D&L did a Muncie for my Chevelle SS around 20 years ago. Great guy to deal with and It came back perfect. He's been in business a while and is well versed in manual transmissions.
Old Jun 5, 2018 | 05:04 PM
OLDSter Ralph's Avatar
Bad throw out bearing ?
Old Jun 5, 2018 | 05:06 PM
Bad throw out bearing or worn clutch fork ?
Old Jun 6, 2018 | 04:13 AM
2oldsguy's Avatar
If it was the throw out bearing it would make noise WHEN the clutch pedal was depressed. His goes away when the pedal is depressed so it is something inside the trans or a real bad pilot bushng.
Joe
Old Jun 6, 2018 | 06:42 AM
Joe
A worn (loose) throw out bearing can "rattle" when clutch pedal is not depressed. The pivots on the clutch fork could be worn and "rattle" a little when no pressure is applied.
The key word is "rattle". That can happen when parts are worn. It could be a bad Pilot bearing also. Checking the easy things first is something to think about.
Old Jun 6, 2018 | 07:26 PM
Fpcopo's Avatar
Are you sure it’s a T10? I thought early 63 was when GM switched over to Muncies. I’ve never seen a T10 in a car that late. Not that it makes a difference a good trans guy can rebuild either one.
Old Jun 6, 2018 | 07:43 PM
Pilot bearing.
Bfg
Jun 7, 2016 10:52 AM
1arunem
Oct 3, 2015 11:11 AM
celodog
Dec 19, 2012 07:56 AM
Al Graaf
Dec 16, 2012 12:02 PM
330noob
Jun 14, 2010 10:27 AM
