Unknown transmission
Old Jul 21, 2018 | 08:00 PM
Wyocutlass71's Avatar
I just bought a 350 olds B block with #8 heads. It came with this transmission that I have no idea what it is! I have th350 right next to it, and they look nothing alike. Can anyone give some help?
Old Jul 21, 2018 | 08:31 PM
That appears to be the dreaded Th200 trans. That’s the only tear wheel drive trans I know of with a one price case/extension housing. The Th250 looks basically the same as the TH350, but has a band adjusting bolt/nut on the side of the case.
Old Jul 21, 2018 | 09:19 PM
Thanks Matt! I have heard of the th200, and was kinda figuring that is what it was, since it came out of an 83 base cutlass. Thanks for the info!! Good thing I have a couple of th350s hanging around my garage.
Old Jul 22, 2018 | 06:22 AM
TH200 pan uses 11 bolts, TH250 and TH350 pans use 13 bolts. Is that a converter lockup wiring plug I see on the driver's side?
Old Jul 22, 2018 | 07:21 AM
When I get some time, I will count the pan bolts today. I am not sure what those wires are but they are there. How can i check?
Old Jul 23, 2018 | 06:34 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Sounds like a Hodge Podged assortment. I actually got sent a TH200 by my local wrecker, not even a lock up like that one, instead of a TH2004R. The skinny one piece design is a dead giveaway, also takes abuse about as well as a wet noodle, both a similar shape.
77olds
Nov 19, 2020 11:26 AM
2blu442
Mar 20, 2019 01:34 PM
Erinyes
Jul 18, 2018 06:57 AM
1968CutlassSupreme
Apr 3, 2018 06:37 PM
Delta88conv455
47
May 20, 2014 05:26 AM
