TH400 2 in 3 Gear shift to late
Old Jul 3, 2019 | 07:43 AM
STLCRZY's Avatar
My TH400 shift late from 2th in 3th gear if power shifting it from hand....in Automatic Modus it shift normaly...hope somebody can help.
I use a Transgo shift KIT if it help
Transgo https://www.summitracing.com/int/parts/trg-400-1-2
Old Jul 3, 2019 | 09:36 AM
Did it do this before the shift kit install? The governor control WOT shift points. You may need do swap or modify your existing governor to get the shift points where you want them.
Old Jul 3, 2019 | 10:02 AM
Are you saying this happens when manually shifting from 2-3 but not when leaving it in D and letting it shift automatically?
Old Jul 3, 2019 | 11:03 AM
lemoldsnut's Avatar
I believe these shift kits can be done with a different pattern of shifts or control. Do you have the vacuum modulator still? Does it get vacuum? You can control 2-3 shift some with adjustment of that.
Hope this helps
Not a trans expert just know a little
Larry
Old Jul 3, 2019 | 10:44 PM
STLCRZY's Avatar
To be honest i cant remember if do this before i install the shift kit...because never drive hard before
Old Jul 3, 2019 | 11:00 PM
STLCRZY's Avatar
To be sure, i will check today ....if remember it shifts late from 2-3 at WOT ....no matter if D or manaual shifting.
Old Jul 3, 2019 | 11:15 PM
STLCRZY's Avatar
Hope this helps
Larry
Yes vacuum work, it don´t feels that this can be the modulator .....from 1th in 2th hard tire chirping shifts when ever i want but if want to shift from 2th in 3th it react later . ( for example shift at400rpm - react at 4500rpm )
Old Jul 4, 2019 | 04:06 AM
Is the 2-3 shift firm, or is the delayed shifting because it’s sliding into the next gear?
Old Jul 4, 2019 | 04:26 AM
STLCRZY's Avatar
it shift Firm...only to late...seems all band are good
pcard
Sep 4, 2024 02:13 PM
truckman5000
Jul 23, 2017 06:03 PM
Fun71
Mar 1, 2015 05:51 PM
350rocketmurderedout
Nov 12, 2014 10:38 AM
johnnyjaws
Aug 10, 2014 02:41 PM
