shift kits
Old Aug 2, 2014 | 09:38 PM
johnnyjaws's Avatar
shift kits
I have a th350 recently rebuilt I want to put a shift kit in it . Should I use a b&m shift kit or a transgo shift kit unless u guys have a better salutation
Old Aug 2, 2014 | 10:36 PM
I have always liked the TransGo shift kits.
Old Aug 3, 2014 | 05:53 PM
techg8's Avatar
I have used both with good results.
I favor the B&M only because I feel the directions are more well laid out.
Old Aug 4, 2014 | 02:36 PM
The Stickman's Avatar
I had a Trans Go HD2 shift kit in my 200 4R and it worked great. Was able to up or down shift at will. Manual shifting really woke the motor up.
Old Aug 4, 2014 | 03:28 PM
76olds's Avatar
Hookers under Hood
I have the TransGo in my 76 Cutlass Supreme TH350 and it works great in my heavy car. Good rubber out of second gear with a lazy long block 350 with 245 60 15 BFG's.
Old Aug 8, 2014 | 07:29 PM
deadeyejedi's Avatar
I just put the b&m in my 72 turbo 350 set up for street strip will soon test drive and post the results first one I ever did and went pretty well
Old Aug 10, 2014 | 06:26 AM
The B&M and TransGo kits do basically the same thing, they just go about it differantly. The B&M is a cheaper kit, they have you drill the holes in the spaacer plate larger, and disable the 2-3 accumulator. The TransGo keeps the asccumulator functutional, has you drill the holes a little smaller, but includes springs to increase line pressure and a stiffer 2-3 shift valve spring so it goes into 3rd gear a little later. The TransGo kit also includes the parts to convert the valve body to a manual/auto. Put the shifter in 1st gear, it will stay in first gear until the engine blows up, or you upshift. It will also downshift to any gear, at any speed. Most stock valve bodies wont hold 1st gear or downshift above a certain point. The TransGo is a more refined, "civilized" shift kit more suited to a daily driver. I prefer the B&M shift kit for cars that have a loose converter, the TransGo kit shifts a little softer at part throttle, with a loose converter you sometimes cant feel the shifts. The B&M TransPac includes all the features of the TransGo, with the harder shift. I can also tell you the TransGo instructions suck, they assume you know how the valve body goes together and just tells you what parts to change. The B&M instructuions are step by step, they tell you exactly what to do and how to do it. Much better if your not familiar with transmission repair
Old Aug 10, 2014 | 02:14 PM
Yes, but you can use factory Low Control Valve spring instead of the blue spring in the TransGo kit and retain the downshift-override function.
I did this on my car so I wouldn't inadvertently downshift at a high speed and trash my transmission.
Old Aug 10, 2014 | 02:41 PM
Just test drove the olds with the new b&m shift kit and love it good solid shifts very happy so far
hvysupreme
Feb 18, 2017 12:40 PM
Alocatelli
Dec 10, 2012 07:49 AM
Oldsproject
Apr 23, 2010 04:19 PM
ctrain22
Sep 7, 2009 10:54 AM
lowdynamo
Jan 9, 2009 09:49 AM
